Go Back   Miller Welding Discussion Forums > Welding Discussions
Reply
Thread Tools Display Modes
  #1
Old 02-06-2008, 01:02 PM
mschjone mschjone is offline
Default What is the best way to weld this thick plate on homemade log splitter?
As you can see we're down to the final stretch on "Homemade Log Splitter Project" Everything is tacked and getting ready to have some fun.
Looking for opinions on the best way to weld this together. GMAW or SMAW?
Main question is welding the wedge to the beam. I want this to be rock solid for obvious reasons. I hope the beveling is obvious from the pics. The wedge is 1 1/4" thick getting welded to the beam that is 5/8" thick on top. I know preheat here will be important, but how much? And how do you tell the temp.?
Stick will give better penetration, right? but can I weld this with my MM251 and get the same end result.
I have .035 solid and .045 solid wire. I also have some Trimark Triple 7 flux core. (I've never used it before) It says, "An excellent choice for a variety of heavy fabrication applications, Triple 7 wire is suitable for use in industries that work with heavy plate or heavy gauge steels such as shipbuilding, railcar and pressure vessel fabrication, along with certain types of pipe welding applications.
If some of you guys think the 251 won't cut it and stick is the only way to go then why?? If it has to be SMAW then what kind of rods??
Any thoughts and opinions would be appreciated. Thanks. Marshall
  #2
Old 02-06-2008, 01:25 PM
Fat-Fab.com's Avatar
Fat-Fab.com Fat-Fab.com is offline
Stick with what you know best.
Your 251 will work just fine. LWS has temp sticks preheat to 250f-350f and weld till you have a 1/2"-5/8" fillet on the wedge, and fill the rest to full thickness with a 1/16"-1/8" cap.
Good luck
__________________
  #3
Old 02-06-2008, 02:14 PM
fun4now's Avatar
fun4now fun4now is offline
Talking
looks good, just be shore the lil hand is out of the way.
anyone ever tell ya you have little girly hand's.
__________________
  #4
Old 02-06-2008, 02:16 PM
MMW MMW is offline
If the triple 7 is .045 then I would use that. It is a dual shield wire so use gas with it. Either straight CO2 or C-25 is fine. Keep the polarity the same as solid wire. Run a couple practice beads on some scrap to get used to it. I think you'll like it.
__________________
TB250g
S-22 feeder
Lincoln squarewave tig 175
Whitney 30 ton portable punch
Lown 1/8x 36" roller
  #5
Old 02-06-2008, 02:17 PM
grpweld grpweld is offline
Default stick or flux core
I used to have a 251 & the only way i would use it would be with flux core 232 or 211 min. I could not get my 251 to spray transfer. If you can then mig would be ok.But why take chances on the most crucial weld on your project, I mean if you hit a knot or something very hard & that breaks it could kill someone standing close by
  #6
Old 02-06-2008, 03:01 PM
diamondback's Avatar
diamondback diamondback is offline
you'r worried about a log splitter when you've got your hood up in the background. Come on where are your priorities, oh wait your welding!
The cored wire will do fine, you can typically run it one size up from solid wire on the same settings. It is going to give you a better penetration pattern in the steel than the solid wire will. The solid wire will be ok if you use it just make sure you follow recommended preheating for that size and control the arc precisely where you want it and you will be fine.
It looks great.
Is it hard to find gloves that fit?
  #7
Old 02-06-2008, 03:15 PM
Nothing gets past you guys in these pictures.
You should see the tight spaces I can reach into with those hands.
The Trimark is .045 and I am leaning towards giving it whirl.
But it's like GRPWELD said "I mean if you hit a knot or something very hard & that breaks it could kill someone standing close by"
I don't want to screw this one up.
  #8
Old 02-06-2008, 03:35 PM
Laiky Laiky is offline
when you done weld a link of chain to it so in case it breaks it doesn't go far. I can't see it actually going flying though, it would probably peal off
__________________
Dynasty 200 DX
Millermatic 175
Spectrum 375
All kinds of Smith OA gear
  #9
Old 02-06-2008, 03:43 PM
ShieldArc ShieldArc is offline
You dont have much of a bevel so you better weld it with 7018.
  #10
Old 02-06-2008, 04:26 PM
J hall J hall is offline
Default When in doubt,use 7018
I'm with Shield arc on this one, I would definitely use 7018
__________________
Jeff
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Please read our Terms of Use. The success of this Forum requires each and every person to adhere to the rules and policies. Messages that harass, abuse or threaten other members; have obscene or otherwise objectionable content; have spam, commercial or advertising content or links may be removed and may result in the loss of your posting privileges. Please do not post any private information unless you want it to be available publicly.
Feedback/Help - Miller Welding Discussion Forums - Archive - Top
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
