Has any one tried tig welding bandsaw blades? I don't want to buy a band saw blade welder if I don't have to. What filler would you use?
Greg
Results 1 to 10 of 10
Thread: Welding bandsaw blades
02-13-2007, 11:34 PM #1
- Jul 2004
- IL
- 7
02-14-2007, 01:32 AM #2
- Dec 2005
- San Diego, CA
- 168
Try this http://www.stagesmith.com/gallery/sh...jig/index.html
The guy has some home built stuff that's pretty nice, I specially like the hyd press.Frank
(aka Fred)
MM200 (antique and still cook'n)
Lincoln 160 buzzzzzz box - left to live with a nice youngster
Dynasty 300DX
Spectrum 625
Chevalier Knee Mill - Bridgeport clone you idiot.
Homebuilt tube bender - with home made dies no less
Delta Drill Press & Grinder collection
Needed - a bigger shop to use the stuff
02-14-2007, 05:28 AM #3
i have tig welded many bandsaw blades, once and a while it will brake at the weld, but seldom, and if it does you just weld it again!
mm210
maxstar 150
02-14-2007, 05:50 AM #4
- Sep 2006
- 1,343
About a hundred years ago I got my first port-a-band, and acquired about 50-blades for the larger port-a-band. I made a jig somewhat like Fred shows, not near as elaborate tho
. Cut the blades to the correct length, and Tig welded them. Had an extremely high success rate. Only suggestion I have is try your best to keep the teeth properly spaced. If you don’t for some reason the miss spaced teeth will snag and tear a section of teeth out
. Not that the blade will break, but you may have an inch or two without teeth, and that’s aggravating
! The blade will still cut, it’s just aggravating to listen to it will cutting, (for me anyway)
02-14-2007, 02:38 PM #5
My blade welder has an anneal function that turns the welded area dull red to return it to a softer and more flexible state. You could do this easily enough with a torch to treat the tig welded area so that it returns to the same state as the rest of the blade stock. let us know how it works out. JEFF
200DX 350P 625 Plasma & other stuff I forgot
02-17-2007, 09:49 AM #6
- Dec 2005
- San Diego, CA
- 168
I should have noted mentioned that I silver solder my band saw blades. Can't tell you the alloy but the solder is wire about .060 in diameter and used with regular paste flux. I've been using it for years and never have broke a blade. I do use the blades on an old HF 14" work bandsaw if that matters. Soldering does eliminate the need for tempering.
That said I think I'll try tig on a couple, let us know how you fair on yours.Frank
(aka Fred)
Dynasty 300DX
Spectrum 625
02-17-2007, 11:02 AM #7
- Sep 2005
- 4,247
My neighbor has been Mig welding them and annealing after, they are for his woodmizer though so they are fairly big and he grinds them flush before the anneal. Seems to work. He was braining this up and down, finally I said, try it.
02-17-2007, 04:48 PM #8
I tryied it once it broke befor I got it back on the machine never did it again
TJTJ______________________________________
02-18-2007, 04:10 PM #9
- Sep 2006
- Okotoks Alberta Canada
- 919
you cheap bugers
I did not know you welded things like that
As far as I knew you just threw them out and got new ones? I have used them for gapping pipe when I spool off my truck. I have a stack of old blades about 6" long and they work well for that
Ohh well each to ther own.
DODGE 1 TON 6.7
PIPEPRO 304
TO MANY TOOLS
JUST WELDING IN CIRCLES
rig welders are like wheelbarrows hard to push around
and easily upset
go flames go
02-18-2007, 04:13 PM #10
- Aug 2006
- Orlando, Florida
- 200
A lot of times the larger vertical bandsaws have blade welders attached to the side of them that weld and anneal them. You just buy the blade in bulk and make the blades to fit.
TobinMM251
Miller Dialarc HF-P 310 Amp Tig
Victor O/A Setup
Lincolin 225Amp Buzzbox
Cummins Freak
