Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
  1. #21
    Oct 2005
    Bulverde, Tx
    1,244
    Suit yourself. I am thinking the VS feeder will act strangley with that much voltage drop...compensated or not. They are extremely sensitive to drops and will not function at all below 15vdc...14vdc with the Extreme VS.
    You may want to do some research on the Dynasty/VS feeder combo on Miller's Ask Andy site. I seem to recall it not being a recommended setup.
    Don
    '06 Trailblazer 302
    '06 12RC feeder
    Super S-32P feeder
    HH210 & DP3035 spool gun
    Esab Multimaster 260
    Esab Heliarc 252 AC/DC
  2. #22
    Appleton, WI
    193
    1000' means more voltage drop. With 4/0 cable that should not be too bad. The major thing to watch out for is welding with all of that cable coiled up. Coiled up cable is a big inductor and will give you bad (sluggish like) welding performance, especially if it is coiled up on a reel.
    Have a great day!
    John Leisner
    Product Manager
    Miller Electric Mfg. Co.
    Owner and user of:
    Trailblazer 302 and Legend 301
    Smith Dual Guard oxy-fuel system
    Various borrowed Millermatics and Spectrums.
  3. #23
    Hopkins, MN
    557
    Talking
    Ya, I prety much decided against using the suitcase on this job. But I'd still like to use the suitcase on a dynasty to save some space. It would be a shaim if I got the suitcase for the dynasty and it wasn't that great, thanks for the heads up on that. How do you get to the "Ask Andy" section, I don't want to spend the money if it works like crap in that configuration.
    And yes it does perform a litle sluggish when using the full length of cable. But as far as the induction issue goes it isn't a problem, every 25' theres a camlock conector, so you just take what you need and connect it to the machine. My buddy originaly just had the full cable hooked to the drum and the drum to the macine, but the insulation stared heating up to much, so he wen't and spent a fortune on connectors. (not that he can't aford it.) I'm jelous of rich people
