    RobStarke Guest
    Default Loading Dock Risers
    I have been tasked with building loading dock risers. (ramp). The specs I have been given are.
    Light enough to be moved by one man
    Strong enough to hold 3 ton vehicle + load
    portable
    one unit (not two wheel ramps)
    Does anyone have an idea or plans that they could share?
    Rob Starke
    hamilton ont canada
    56
    Smile
    HI rob what kind of materials are you go to use for the project . Steel or aluminm and do you have move on unever ground our flat ground
    21
    Default lift
    is this the dock riser's they use for forklift's to be picked up and moved where needed. Aluminum I believe is what that is.
    British Columbia
    500
    Cool Ramps one or two wheel
    Here ya "go" These should help.
