Results 11 to 12 of 12
    Olive Branch Ms
    129
    Default update
    Thanks for the help. My cooling unit is integrated in the machine. The flow indicator started working after about an hour of tigging. I have been trying to do some overhead tigging of 4130 tubing. My welding instructor advised be to forget the pedal and use the lift arc feature. It took a while to get the current set right but it does okay til I pull away. The arc starts dancing and messes up my last puddle. I went back to using the pedal and it went much better. A guy here at work suggested rigging up a way to attach the pedal to my foot or getting a hand remote for use when welding out of pos. Thanks, Adam
    now in Orlando!!!!
    559
    Sorry I did not see this earlier, I had the same problem with my cool runner, I just pulled the cover off and when I put it back on, did not push it on as far, you might just try tapping it if it acts up again, best regards, I used to do a lot of stick welding on car haulers, the big ones, and I would use the hand remote to set amperages with stick. it worked real slick, sometimes I would also pulse stick. Hope this helps ya, Paul
    More Spark Today Please
