Results 11 to 20 of 30
Thread: tricks of the trade
03-04-2007, 07:03 PM #11
Dynasty 200DX, first generationMakita 5" grinder
Makita 14" abrasive sawIR SS5L compressorWhole bunch of hand/air tools.and a wish list a mile long
03-05-2007, 05:06 PM #12
- Jun 2006
- St. Louis, MO
- 3
Earplugs are cheap insurance, just like safety goggles. I rarely do anything without earplugs in while out in the shop. You'd be surprised at just how loud MIG welding really is.
As far as tricks.... always easier to make/modify cardboard than steel. Make patterns/templates for everything and write down what project they were for, which way they pointed and what modifications you had to make in case another one comes in the door later.
If you've got kids, cereal boxes are great for templates. Plus, you're recycling!
03-05-2007, 06:16 PM #13
Trick
Well when you die grind aluminum use WD40 on the metal and on the bit and you will get the best results. But remember use a full face shield and guantlet type gloves.She really cuts up a storm
03-05-2007, 07:07 PM #14
re:trick of the trade
keep the gloves on and the jewelry off i was welding overhead and had to put steel incert in a ceramaic brick and weld it with a mig welder thin i check the weld and the cherry fell out and stuck to my watch
i could not get it off until it cooled and i did i pleed off the skin thats real smart terry welds
miller bobcat 250
wc 115a
spoolmatic 30a
centery 250 mic
2 lincoln 225 stick
a 1954 hobart portable welder w/ willies jeep engine
03-07-2007, 10:59 AM #15
try teaching someone to weld is always good it gives u the chance to train someone but also evaluate how u weld in the process. Then u can change ur style around a little bit and possibly either learn a new technique or tweak ur own so tht way ur welds are a lot better.
03-07-2007, 01:47 PM #16
- Nov 2006
- Hampton, Va.
- 383
03-07-2007, 09:00 PM #17
- Feb 2007
- 6
Thank you Steve for helping clarify my earlier post. Ventilation is very important when welding any material especially galvanized/zinc. However I did want to add another idea, when welding tube together a small hole by the weld allow the hot gases to excape and prevent porosity in your weld.
03-09-2007, 04:57 PM #18
- Feb 2007
- 6
When you have to grind your weld grind "with" the weld so your grind marks go across your weld not through it. This will help prevent a failure in your weld.The failure is more likely to go across your weld instead of through it.
03-11-2007, 07:46 AM #19
- Nov 2005
- michigan
- 47
"keep the gloves on and the jewelry off " I was whereing my wedding ring in class got a piece of splatter stuck to my ring burn my finger all the way around and took a nice chunch of my ring
miller 330 a/pb tig miller 175 mig
student and hobbiest
03-11-2007, 09:19 AM #20
If you preheat to weld..........never test it with your tongue...
Never jump out of an airplane while tigging.....
If these help, I have a lot more
