just for the sake of arguement this was brought up today and i wanted to see what everyone else thought........here goes!!!
if you had 1/16" flux core wire and was doing Vert. and Flat......how wide is max??? I say no wider than you thumb but others disagree.....what do you feel???
________
Honda C200
Thread: flux core question?
03-02-2007, 06:17 PM #1
flux core question?
03-02-2007, 06:36 PM #2
I guess it depends on how "wide" your thumb is. It could be 5/8" wide, or 1/3/16". Your question stumbles me at the vert. flat part. Running vertical weave as opposed to vertical stringers has differnt parameters. For flat, the same thing, but not the same as vertical.
Jonny
Dynasty 300DX
Esab PCM 1000
03-03-2007, 12:20 PM #3
ok so how wide max. would you go for a vertical weave??
________
Vaporizer guideLast edited by WillietheWelder; 02-28-2011 at 06:22 PM.
03-03-2007, 08:02 PM #4
- Feb 2007
- asheville n.c.
- 595
i use the stuff for most of my weldig and dont go more than 3/8 on width of bead. i run it about 25 volts or higher, and pretty quick wire speed. most of my welding is on structural steel.
03-03-2007, 08:07 PM #5
I don't normally use 1/16" often, however with .045" I generally keep a verticle weave limmited to 3/4" for structural welds. If the joint design requires more weld across the face, I use overlapping weaves or just use stringers.
Jonny
Dynasty 300DX
Esab PCM 1000
