    407
    Default Rg-60 Filler For Tig
    can i use RG-60 filler rod for tig welding mild steel ??
    my local supply shop said i can, but when i use it compared to ER70S2 filler, it looks kind of different.
    i had some laying around and decided to try it out, but went ahead and bought some ER70S2 filler to be safe.
    just practicing for now, not welding anything critical.
    thanks....
    SyncrowaveŽ 200
    Lincoln AC/DC 225/125
    Jun 2007
    482
    The jist of it is, yes you can use it, but no you should not.. It's is an oxy/fuel welding filler and not suitable for tig work.
    407
    thanks benny for the help.
    my supply guy is a waco. LOL.
    little by little i will aquire different fillers so i can have the right filler for the job.
    thanks again.
    SyncrowaveŽ 200
    Oct 2005
    Central Florida
    193
    The slightly longer answer is that O/A filler metal does not contain the deoxidizers that MIG/TIG wire contain. O/A welding keeps the workpiece hot enough long enough that the COx can evolve out of the weld; TIG does not. The potential result is porosity in your weld.
    Regards,
    Bill
    "The more I learn about welding the more I find there is to learn..."
