i dont much care for the new harlys eather, a harly has always been loud and simple, kinda like an old truck that just refused to keep up with the new tec. its just waht it is, the new ones just dont look or feel harly. although i cant aford one if one was given to me and ihad the option of a new one or an older one i would have to go with the older one if i had to keep the one i chose, if i could sell it i would go with a new one sell it to a yuppie and build myself one frome parts to be just right for me. and it would have a 4 speed, if i did pull a trailor it would be a light one so the 4 speed should be fine.and there is just some thing about a kicker that just has to be there ya know.
Results 41 to 50 of 70
Thread: 6 speed tranny's for Harley's
12-07-2006, 09:51 PM #41
james@newyorkmetalart.com
12-07-2006, 10:50 PM #42
- Sep 2005
- S.W. Pennsylvania
- 2,249
Kelly;
Let me know next time you're in town, I'm about 50 miles south of Pittsburgh in Greene County. Maybe you could give me some pointers on this tig of mine.
You should fill in you're location, who knows, I might be in you're peice of the world some day.
James;
A good friend of mine down near Cincinnati Ohio started with a seat he got at a flea market and eventually built himself a Harley. Rose thought he was nuts when he brought the seat home and told her it was there new bike.
If you want one, I believe you will eventually end up with one, although cheap parts are getting harder and harder to find now days with the craze thats going on. I also like simple, thats why I did away with the electronic ignition and put a magneto on mine.
As far as pulling a trailer, they all will do that just fine, unless you plan on trailering you're car to the track with you're bike. I noticed on the speck stuff from Harley that Trent posted they mentioned increased hauling capacity. After you get so big that becomes a mute point. like harcosparky said of his freinds 750 CC BMW with a side car and two passengers, if that can do it, so can any Harley. I wish you the best and look forward to seeing some progress picture's of youre new used bike.
I think if I were to go with 6 speeds I would want 4 of them set up like my 4 speed and the other two to be about 15-1 at the rear wheel with one of them being a reverse, the other a granny gear for crawling out of hairy places.
Thanks to every one who participated in this thread so far, I've enjoyed the input.
My sincere thanks , Pete.
Pureox OA
Westinghouse 300 amp AC stick
Miller Syncrowave 250
Hexacon 250 watt solder iron
12-09-2006, 09:06 AM #43
- Sep 2005
- S.W. Pennsylvania
- 2,249
Hay James ;
This looks like an afordable starter bike.
Just ran into this and could not resist posting it.To all who contribute to this board.
Pureox OA
12-09-2006, 01:46 PM #44
- Oct 2006
- 642
12-09-2006, 03:34 PM #45
- Jul 2006
- Sarnia,Ontario,Canada
- 28
Just so you know, a helical cut gear is stronger as well as quieter than a straight cut gear due to more contact area on the tooth surface of the helical cut gear. The only real disadvantages to helical cut gears are that they produce side thrust and must be in constant mesh with its mating gear. Straight cut gears with the assistance of syncro's can be engaged and disengaged quite easily and produce no side thrust.
Tek
12-09-2006, 04:19 PM #46
- Sep 2005
- S.W. Pennsylvania
- 2,249
I don't know about the 6 speed tranny's but on the 4 speeds all the gears are in contact at all times. Shifting is accomplished through shifting clutch dogs that slide between the gears in effect locking or unlocking them to the mainshaft or counter shaft. Page 26 of this Andrews catalog shows the clutch dogs as figure C.
http://www.andrews-products.com/Down...torcycle05.pdfTo all who contribute to this board.
Pureox OA
12-09-2006, 04:41 PM #47
- Jul 2006
- 28
Thanks for the link burninbriar, I've never seen the inside of a Harley gearcase and I'm always looking to learn something new. I was referring to gears in general, not necessarily harley transmissions. In applications where the engineers wish to couple and uncouple 2 gears by sliding one of the gears over on a shaft until the teeth mesh with the other gear you will see straight cut gears. Typically, when you see a helical cut gear it will be in constant mesh with the opposing gear.
Tek
12-11-2006, 10:03 PM #48
- Mar 2006
- 124
harco; where did you get the 27 hp R75/5 BMW numbers from?
The new bigger 750cc R75/5 came out in 1970 with 50 hp and 43 ft/lbs tq with
4 speeds until the 1975 R75/6 series began with the 5 speeds.
Depending on solo or sidecar use it could be ordered with the option of two different rear drive gear ratios. I'll take my R90/6 or R90s on a trip where 600-800 miles is a daily thing going across country, funny thing I can't find the dirty chain and I can go from California to Florida without parts falling off.
"Beemer Nut" on other forums.....=o&o>.....
12-12-2006, 09:34 AM #49
- Sep 2005
- S.W. Pennsylvania
- 2,249
12-12-2006, 09:53 AM #50
- Mar 2006
- 124
Testing for reactions. Usually I get the single finger salute within the 50 mile radius of home by beep beeping a broken down Harley, even if they ride home in a pickup bed.
On the open road and at rest stops Harley owners are nice polite people that also like to ride. Fun to guess at how people act against different brands of scooters, to me I just enjoy the ride.
.....=o&o>.....
