Page 1 of 7 123456 ... LastLast
Results 1 to 10 of 70
    S.W. Pennsylvania
    2,249
    Default 6 speed tranny's for Harley's
    I'm putting new gears in my 4 speed ( 1984 Soft tail ) and a lot of people ask why I don't spend a little more and get a 6 speed tranny. I don't get this 6 speed stuff, I don't use the 4 gears I have most of the time. This whole idea of adding more gears to a bigger inch motor just seems backwards to me. More gears is usually to help an under powered engine. Having 100 plus inches and adding 2 more gears seems like a lot of extra weight and shifting with no real gain. What I'm doing is putting a lower first ( 2.60 in place of a 2.44 ) and upping my high end with a larger transmission sprocket and a smaller wheel sprocket. ( 24 and 49 tooth) This puts 1st very close to stock and a 4th cruising speed calculated at about 74 mph at 3100 rpm. Thats about 300 rpm less than stock.
    I just have an 80 inch engine and I think this gearing will serve me well on the street but I think if I were to drag race a 100 inch or bigger I would be tempted to go with a 3 speed. Any way, I was just wondering if any one here is racing the big inchers and what they are using transmission wise ? Also any comments from any one using a 6 speed ?
    If any one is interested, here are my new ratio's.
    primary - 1.54 / 1
    1st - 2.60 / 1
    2nd - 1.82 / 1
    3rd - 1.23 / 1
    4th - 1 / 1
    final - 24 - 49 front & rear tooth count
    Here are my old ratio's.
    primary - 1.54 / 1
    1st - 2.44 / 1
    2nd - 1.65 / 1
    3rd - 1.23 / 1
    4th - 1 / 1
    final - 23 - 48 front & rear tooth count ( stock had a 51 tooth rear )
    With my health the way it is, I was considering trying to find a tranny with a reverse in it. Then decided, naa. I want to keep first slowed down for when I get out in the National forests and such.
    My sincere thanks , Pete.
    Pureox OA
    Westinghouse 300 amp AC stick
    Miller Syncrowave 250
    Hexacon 250 watt solder iron
    if you are not planing on racing it there realy dosent seem any point to the 6 gears. like ya said you have no need to stay in the power band just crose it.
    a reverse might not be too bad an idea, i dont know what they run $$ wise but on a big bike it could come in handy. i know they make them just dont know how much $$ it would be or if its werth the $$ to ya.
    man i gotta get another bike.
    6,764
    On the lower displacement engines like your puny harley, true there isn't much point getting the 6spd, though on my IronHorse texas chopper running a 124 CI with alotta extra torque and zoom power it's nice to have the extra gears.....
    Jul 2006
    Sarnia,Ontario,Canada
    28
    And youll need them to catch the Honda's
    ummm.... .......... dont you mean to TRY to catch the honda's.
    S.W. Pennsylvania
    2,249
    I think you missed my point. On my 80 CI, I have enough extra power to spare that if I'm in 1st gear I'll skip second and go directly to 3rd, or if I'm in 2nd, I'll skip 3rd and go directly to 4th.
    On you're 124 CI, are you running all 6 gear's consecutively ? Its hard for me to imagine there being much difference between gears since the first five run up to a direct drive the same as my 4 speed, the only difference is the overdrive, I think its like .86 / 1 ratio. Do you know what the 1st gear ratio is on the 6 speed ?
    Pureox OA
    Mar 2005
    South Eastern Manitoba
    29
    Thumbs up
    Keep the 4 and the kicker.
    your just cruzzzing along like it was ment to be ridden, i agree keep the 4.
    Langley BC Canada
    4,634
    Default my 1.5 cents
    I'm not anything close to an expert about the two wheeled variety, in fact I'll go so far to say that I don't know squat about a bike unless its on dirt, and then I know just enough that is learned as boys on their toys playing in the mud, but IMHO, for most of the riding people will do, the 6 speed is 2 gears cooler than the 4, that's it If you put them side by side and said to me which one, of course I'd take the 6, whether or not the tradeoff would actually be worth it for a 6 clicker, well....... now that's using logic, and sometimes that stuff just don't belong, but at least I'd be able to say it had the 6
    Glen N.Y.
    902
    Hey Pete,
    The need for a six speed comes in when the engine builder builds an engine with a very narrow power band. Some guys like a cam that is quick reving and builds power real fast so you get super quick acceleration but with that you loose power quick as well so time to grab another gear. Now on your mostly stock 80 incher that has a cam that builds nice power over a real wide range, if you were going to go after some ricers you would most definitely need to change the cam and rework the heads, change the rods and get that 6 speed. In 94 I won the Easy Rider horsepower shootout with my 80 incher and Skeeter Todd on the seat from Easy Rider(121hp at the tire). This thing would eat CBR 600s, but was no match for the CBR 800's.
    Good luck,
    Bulldog
    5 Passport Pluses
    2 MM 212's
    MM 210
    MM 251 MIA
    MM 350 P w/Python
    w/ tig runner
    Trailblazer 302
    12RC w/meters
    Spectrum 1000
    Spectrum 2050
    2 Black BWEs
    Joker BWE
    Star & stripe BWE Digital
    2 star & stripe xlix's
    REAL TRUCKS RATTLE
    CUMMINS BABY
