Page 1 of 3 123 LastLast
Results 1 to 10 of 29
    British Columbia
    500
    Cool The making of a new bumper
    This is a 2006 GMC 3500 1 ton dulley I have to take the new bumper off through it away and build a new one that will support a winch and hooks
    British Columbia
    500
    Cool day 2
    Fitting and cutting
    Jun 2006
    Calgary, Alberta
    377
    Did you tie the HSS into the frame ends with the front cross member tube? From the pictures it looks like you did. Looks good and strong.
    Jonny
    Dynasty 300DX
    Esab PCM 1000
    British Columbia
    500
    Cool Hss
    The hss slides into the frame and I bolted it to the frame so the hole thing slides out for painting or maintenance repairs on the last set I welded to the frame on the last truck customer change there mind again.
    British Columbia
    500
    Default Fitting and Welding
    Here's a few more pics
    British Columbia
    500
    Well I'm almost done should be finished tomorrow then it goes out for paint
    Brookfield,MA
    103
    is the customer going to spring for powdercoating?, great work, looks really good
    Trailblazer 302G
    MM 210 with spool gun
    Thermal Arc Heffty2 CC/CV suitcase
    Smith torches
    Porter Cable 14" carbide chop saw
    griders and hand tools coming out the WAZOO
    I owe! I owe! so off to work I go!
    British Columbia
    500
    Cool The last of it
    Well here it is the last of it before paint the paint will be epoxy white
    hey thats not my colour
    British Columbia
    500
    Cool Finaly Done
    well this is 1 of 5.
    Spruce Grove, Alberta,Canada
    583
    Default bumper
    Quote Originally Posted by Darmik View Post
    Is that bumper a warn winch bumper that you built a mount for or did you build it from scratch?
