Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
  1. #21
    Wartburg,Tn
    575
    I play my radio while I `am working if you can`t hear turn it up!
    Inferno Forge
    Chris
  2. #22
    Oct 2008
    I use head band ear phones under my helmet. The wire goes down my back and into the player in my pants pocket. One of those small clamp type paper clips holds the wire to my shirt collar on the back which stops the wire from falling around the front when I bend over.
    I've tried lots of brands and most are uncomfortable after a couple of hours. The plastic band that connects the speakers presses behind the ears. I've now settled on "KOSS SPORTA-PRO" which don't have that problem because they have a foam pad just above the ears to hold them in place. They also allow in just about all outside noise which may or may not be good for you depending on your situation.
  3. #23
    At work i turn up the radio louder than anyone else, but you have to be able to hear people around you...anything can happen. After the guy behind you almost breaks the valve off the acetylene cylinder, you dont want to lift up your lid and realize you are the only guy in the shop because everyone else got the f@ck out of there before it went off like a toprpedo. Don't listen to earphone/earplug music in the shop or in the field even in your garage for that matter...you won't hear your wife yelling that the house is on fire. Just crank the boom-box.
  4. #24
    Feb 2008
    flat , and lots of dirt
    123
    Default Question?
    Those of you that use a portable mp3 player while welding-
    Will HF start damage them? I had to retire a grinder last week that I assume was damaged by my welder, I'd hate for it to kill my mp3 player too.
    SYNCROWAVE 200
    Atlas 618 lathe (vintage 1960) reconditioned DC
    Sioux 3/8 Pneumatic Reversible Drill
    Makita Everything else
    2400 square feet of Sanford and Son lookin shop space
    "Once the spoon flys, putting the pin back in won't solve anything"
    USA 15T, 15V
    www.myspace.com/blackbird455
    http://i100.photobucket.com/albums/m...5/DSC00356.jpg two cans, one welder
  5. #25
    Nov 2007
    Saskatoon, Sask, Canada
    1,270
    Quote Originally Posted by Blackbird455 View Post
    It doesn't seem to. Lots of guys use them at work tigging aluminum all day and so far so good.
    at home:
    2008 Suitcase 12RC
    Spoolmatic 30A
    WC-24
    2009 Dynasty 200DX
    2000 XMT 304
    Sold:MM130XP
    Sold:MM 251
    Sold:CST 280
    at work:
    Invision 350MP
    Dynasty 350
    Millermatic 350P
  6. #26
    Feb 2008
    123
    Thumbs up
    10-Roger-4 , consider me rockin when weldin from now on.
    SYNCROWAVE 200
    USA 15T, 15V
