Results 11 to 13 of 13
Thread: Newbie question
    105
    Post
    heyy matt .. is this regarding the trailer??.... if so all the welds on it are fillet and lap welds, no butt welds .. i have almost the same welder too and i just bevel the ends and put right together.. i've done this up to 3/8 thick tube witch needed to hold like 6000lbs with the little welder!.. that was before i got the 251 tho.. but it proves the little welders are a very good investment.. anyways if you have any questions about the trailer just e-mail me.
    Jorgensen MFG.
    argonweld_bjorn@hotmail.com
    www.ehhitch.com
    collinsville, ok
    86
    yes the gap makes it an open root joint. when done correctly, it will penitrate the back about a 1/16th. it should look like you ran a bead across the back side of the plate. when running mig, i knife the bevel. alot of guys put a small land because they run hotter than me. after i get the root and hot pass done i'll turn it up and go for broke. the root is the most important part.
    Northeast
    11
    Hey Bjorn, Not so much about the trailer. I just want to practise and do it right. But back to the trailer-I'm assuming the outside frame is mitered 45 deg. Would I also bevel the 2 pieces? It seems I may be getting in over my head a bit about this trailer. I think I will have to put it off for a few months until I am better at welding. I'm taking a class at the local college but they teach almost all oxy/act welding on thin metals(automotive). That's the only class offered in the state unfortunately. Iknow someone who has been welding for sometime, and when I build it, I'll have him over to supervise.
    Hobart Handler 187 MIG
