How important is it to use the grinding wheel for tungsten only ?
I am using the wheel for drill bits also.
Am not preasure welding pipe, only playing around with home projects , so losing a percent or two of strength is not a big deal.
Also the owners manual suggests diamond wheels, the cheap aluminum oxide wheel seams to work fine. Is this a bad idea ?
02-11-2007, 10:45 PM #1
- Feb 2007
- Canada
- 16
Dedicated wheels fror grinding electrodes
02-12-2007, 06:13 AM #2
- Jan 2007
- 53
dedicated wheel
It is very critical when you are doing code welding, but if you are like me, i do minor aluminum repair, boats etc.,thin sheet metal and such you should be fine. I bought me a small cheap bench grinder and it is only used specifically for grinding electrodes,the tungsten grinders are very expensive . Although it mite not be a good practice but it works for me!
/22x45 concrete slab with 2 overhead cranes(trolley style with electric hoist, huge shade tree to weld under
33x33 enclosed shop when its to cold or windy outside
miller 210
miller 875 plasma
victor oxy/accet
unihydro 45ton ironworker
miller 180 tig
ole lincoln ac/dc buzzbox
milwaukee power tools
and everything in between
2007 trailblazer 302
Bailiegh 210 miter saw-2008
Beer Fridge
6000# cat forklift
36" port-a-cool fan
Dake G-75 Belt grinder
3035 Spoolgun
02-12-2007, 10:43 AM #3
shade tree welder is right you must use one wheel of your tungsten and use it for that purpose only. cuts down on many arc stating and weld bead problems.
trail blazer 302
hypertherm plasma
millermatic 251
high feq. arc starter
suit case (extreme 12vs)
o/a torches
02-15-2007, 07:00 PM #4
Sounds crazy, but a flap wheel or a sanding disk makes a pretty good sharpener on a disc grinder. and you can dedicate it to just that. Hopes this helps, Paul
02-19-2007, 03:45 AM #5
- Sep 2005
- 76
Grinding Tungsten
Take the advice of the pros - dedicate a griding wheel to your tungsten. I went to Harbor Freight and bought a $19.95 grinder for that purpose. If I ever get to the point of second guessing experienced welders - I follow their suggestions.
Steve
