Results 1 to 10 of 11
    Feb 2007
    3
    Default Carbon Steel to Stainless Steel
    I'm working on a project that requires welding carbon steel bracing to the outside of a stainless steel tank.
    Which will give me the best job for penatration and over all appearance?
    (316L Stainless Steel wire or the ER70 Carbon Steel )
    Salem ,Ohio
    3,953
    Cool
    Since you didn't specify the SS specs for the tank i am assuming it is 316. I would use 309 wire to weld it...Bob
    Dec 2005
    Dallas, TX area
    267
    Default Be VERY careful.....
    If the vessel you plan to weld on has an ASME certification and you are not certified to weld on vessels, the vessel must be re-tested/certified to ASME specs. Just FYI.
    Triggerman
    Ammonia refrigeration tech
    Trailblazer 302 (yes, it's new)
    Millermatic 180 w/Autoset
    CST-250
    HF-15 High frequency
    XR15 w/Push-Pull Gun
    Victor O/A, DeWalt, North mask
    "A professional knows what to do. A craftsman knows why."
    Feb 2007
    3
    Default Carbon to Stainless
    The tank is 48"X48"X26' Non pressure constructed from 1/4" 304 SS.
    Welding the tank is not the problem.
    Welding the bracing to the sides is where we are haveing trouble.
    The Stainless wire does not seem to be penatrating the carbon steel bracing.
    It's just rolling over with what seems to be little pentration.
    Any suggestions??
    Dec 2006
    Kamloops BC
    15
    Default Use 309L wire or stick
    You need to use 309L electrode because of the dissimilar metals. I have done lots of carbon to SS at the pulpmills in the past. This may not be the best way, but I do know that it works and is what I learned during my "A" ticket in BC. 309L has the most carbon "memory" I think that is why it works best with Carbon to SS.
    My 2 cents...hope this helps!
    Steve Senger
    Dec 2006
    Alaska
    732
    Default the higher Alloy
    Allways go to the higher alloyed material. AWS D1.1 chapter 6? I think
    TJ
    TJ______________________________________
    Dec 2006
    Kamloops BC
    15
    Default Higher alloy!
    Always use a higher alloy when welding SS to SS. EX: 304 SS to 309 SS use 309L or higher. Good Point Fat ****, and there is a good reason why 309L is for carbon to SS, I just wish I remembered.
    Steve Senger
    Feb 2007
    3
    Default Thanks
    Thanks for all the help and input.
    I'll give it a try.
    Sep 2002
    Clark County, NV
    2,696
    Ditto. E309 sticks or ER309 wire is the tool for the job. Start there and let us know how it goes.
    Feb 2007
    West Farmington, OH
    746
    I've done quite a bit of welding stainess to carbon steel, 309 is the best way to go whether electrodes or wire, if you're going to MIG weld it you'll probably want to use a tri mix gas Argon, Helium & Co2, I've used 90/8/2 with good results. Praxair has a tri mix called Helistar that works well too.
    Good luck
    Blondie
