Results 1 to 9 of 9
    Aug 2006
    gallatin tn
    16
    Default galvinized metals joined to carbon steel
    can galvinized be joined to carbon steels?
    Salem ,Ohio
    3,948
    Cool
    Yup, weld or solder...Bob
    Mar 2006
    e-town, ky
    382
    wear a respirator.
    marty
    Miller Synchrowave 250
    OTC 300DM with external wire feeder
    Miller XLi Dale Sr., fibre metal hoods
    Metaltek of Ky. Inc.
    Home of the Stephensburg weld
    Jun 2006
    Maine
    732
    Quote Originally Posted by martymar333
    wear a respirator.
    marty
    yeah, you never quite get over zinc poisoning.
    Bobcat 225NT
    Cutmaster 52
    Lincoln Weld-Pak 100 buzz box
    Caterpillar TH63
    '07 Kawasaki ZZR600
    Aug 2006
    gallatin tn
    16
    thank you for the help it was a question for school
    Jan 2005
    Paradise, Ca
    131
    Or, I dunno, you could grind the galvi off the steel before welding.
    May 2005
    600
    as stated it can be welded (excepting GTAW), soldered, or brazed.
    Bretsk2500,
    poisoning is a bit strong, let's keep it to Zn sickness, you're gonna get sick, not die. (please, no PawPaw references, extenuating circumstances lead to his demise)
    Jun 2006
    Maine
    732
    Quote Originally Posted by PUMPKINHEAD
    Bretsk2500,
    it may be a bit strong, but that is precisely what it is, poisoning. I have no pawpaw references, but I did manage to give my self zinc chills once when I was much younger welding on a bunch of old galvanized fence posts. I try to be more careful now.
    Bobcat 225NT
    Cutmaster 52
    Caterpillar TH63
    '07 Kawasaki ZZR600
    Mar 2005
    Dayton Tennessee
    514
    Bretsk2500,
    If you use proper precautions, you won't get "sick"
    Don't minimize the danger that welding galvanized metal can cause!
    I agree with Bretsk2500 it IS poisoning!
    Syncrowave 180 SD
    MM185 with 3035 Spool gun
    1971 Roughneck 1e
    Stars-n-Stripes BWE
    Optrel Satellite OSE
    ESAB 875 Plasma Torch
    Lincoln 200SA Diesel
    O/A Set
    Century 250A/C-D/C BuzzBox
    1.5 kVA Spot Welder
    Phoenix Electrode Conditioning Oven
    Professional Auto Mechanic since 1974
    My own shop since 1981
    Cya Frank
