Results 1 to 10 of 10
    Question cut off screen ??help
    is any one else having truble getting the hole screen on this site??
    seems like i just upgraded (yea right ) to the new internet explorer that just came out and now i cant see the hole screen when i am posting ?? its cut off on the right side just after the first set of smilies ?? i took a screen shot pic of it to show you what i have got.(see pic)
    any one else having this problem? not shore if its related to the upgrad or if its just timeing making me think s o.
    any ideas how to fix it??
    i do not have the same problem at the other miller board i dont think, i'll dubble check and get back on that one.
    Jan 2006
    Albuquerque, NM
    1,788
    Same problem here.
    Regards, George
    Question
    nope all is fine over there (see pic)
    is this a new problem for you also ??(last month or so) and did you upgrade your explorer ??
    304
    I thought that was normal. Mine has always done that. I also use mozilla and it does the same thing.
    Jan 2006
    Albuquerque, NM
    1,788
    Yep, I went to V7 I think it is.
    Regards, George
    Wichita, Kansas
    107
    is any one else having truble getting the hole screen on this site??...
    My display is identical to that shown in your pic. It's always been that way for me, but I switched to IE v7 before I encountered this forum.
    I have noticed that "youngerwelder's" posts extend out past the right margin into the black area. His are the only ones I've noticed doing that.
    any ideas how to fix it??...
    Nope. I suspect it's some quirk in the forum/server software settings or in IEv7 which makes them somewhat incompatible with each other. The only downside I've noticed is that I have to use the dropdown list above the edit window to select a "smilie" instead of from the array at the right of the screen. Another forum I frequent seems to use the same forum software as this one - though with different settings or possibly a different software version - and everything works as expected over there.
    Tom Veatch
    Wichita, KS
    Suffield, Ohio
    344
    Mines been like this for about a month now and I haven't upgrade anything.
    Jun 2006
    Calgary, Alberta
    377
    I have had it happen twice in the past month, but things return to normal after shutting down for the night.
    Jonny
    Dynasty 300DX
    Esab PCM 1000
    do you mean after you shut off your computer at night or after leaving the site ??we never turn off our computer..well rarly do we shut it of, usualy just when upgrading stuff.
    i didnt notice they had a drop down for the smillies, gess im good to go now. although it would be nice if it works right.
    i think his post going of to the side is due to him inputting larger pic's, although it could just be the way he post with a diferent program ???
    FWIW i did let miller know it was doing it just incase they did not know, so i'm shore they will figure it out and eather fix it or tell us how to reset the new broser if its about the new explorer.
