Results 1 to 10 of 14
    Jun 2004
    Pittsburgh, PA
    111
    Default Serpentine Belt Splitting Down The Middle
    This isn't a welding question, but there are enough threads here regarding motor vehicles so I'll go ahead and post this along with a photo of the belt in question.
    Ever see a belt split down the middle like this? I have no clue what happened as it was fine last time I looked under the hood. It's very fortunate that I found this at home this morning when I opened the hood to add a can of R-134A or I could have been stuck on the highway in the 95 degree heat. It still turns all of the pulleys, but there is only half a belt. Going to get a new one as soon as NAPA opens and install it this evening when the temperatures will be cooler.
    Lafayette, La
    319
    Never seen anything like that. Those belts are pretty tough. I'd make sure there are no hose clamp ends or metal brackets touching the belt before installing the new one.
    Jun 2004
    Pittsburgh, PA
    111
    Quote Originally Posted by wb5jhy
    I fully intend to check for anything that could have cut into the belt, as well as the alignment and rotation of everything that this belt turns.
    Jun 2006
    Maine
    732
    check all of your idlers and pulley for wear. my '88 chevy did that for a while until I discovered that one of the plastic idlers had worn a taper into it and was forcing the belt onto the edge of the A/C compressor pulley. I replaced the pulley w/ a metal one from NAPA and it's been fine since.
    Bobcat 225NT
    Cutmaster 52
    Lincoln Weld-Pak 100 buzz box
    Caterpillar TH63
    '07 Kawasaki ZZR600
    Aug 2004
    guilford, ct
    858
    i second bretsk.
    Trailblazer 302g
    coolmate4
    hf-251d-1
    super s-32p
    you can never know enough
    Queens NY
    1,547
    i've seen it happen on occasion, not often though. How old is the belt?
    Dynasty 200 DX
    Millermatic 175
    Spectrum 375
    All kinds of Smith OA gear
    yep check the alignment to find the cause, some thing must be out of alignment.nice of it to keep 1/2 still on to get you home, good truck buy it a fresh round of oil to say thanks for saving you a walk.
    Jun 2004
    Pittsburgh, PA
    111
    The belt is only around a year old and I just gave the engine fresh oil and a filter less than two weeks ago.
    Langley BC Canada
    4,635
    I've seen that happen for two reasons:
    1. the belt was either defective, old and checked, or had cut and develops a flap that peels itself off.
    2. someone leaves a rag under the hood, serpentine belt eats the rag, momentarily rides on the bunched rag and gets out of alingment and splits the belt.
    Jun 2004
    Pittsburgh, PA
    111
    I think I figured out what happened. The idler pulley is rubbing against the mounting bracket. This probably caused the edge of the belt to rub which in turn caused it to tear. I'm really surprised that belt split cleanly in half instead of just breaking. I found the other half of the belt wrapped around the back of the fan. Of course that is very lucky for me since it didn't leave me stuck. The vehicle in question is a 1997 Jeep Grand Cherokee with a 4.0L I6. Attached is another photo highlighting the problem.
