Results 1 to 7 of 7
Thread: hitch tube
    Jan 2007
    105
    Question hitch tube
    anyone else here build hitches and custom trailers?
    i got a question where can i get 3x3 by 1/4" wall tube **SEEMLESS*.. i've been looking for it for ages. i want to make custom class 5 2.5'' opening. I know Curt and Cequent both make raw class 5 hitch tubes but there like $90 each and there only 18'' long.
    Jorgensen MFG.
    Custom trailers:from utility to semi trailers i make em all.
    argonweld_bjorn@hotmail.com
    www.ehhitch.com
    Salem ,Ohio
    3,654
    Cool
    So what you want is a piece of tube without the weld sticking inside. Hitch tubes are "broached" to remove the weld. You can have two channels made in a sheetmetal fab shop and weld them together [ ] but then it will have a radius corner inside....Bob
    Jan 2007
    105
    i want just to get the seemless tube tho... the channels wont work cz it has to be rated for enough weight and the welded channels would look hoaky. The hitch manufactures must get it from some where tho... i'm not only making one or two hitches i'm going to manufacture them for stock.
    Jorgensen MFG.
    www.ehhitch.com
    Jan 2007
    Alberta Red Deer
    373
    your local steel yard doesn't have that??!!!
    Apr 2006
    southern Oregon
    19
    Call around the local steel suppliers. That is where I get mine, it is somewhat more spendy.
    Don't ask me to do a dam thing, I'm retired
    Miller Syncrowave 250
    Linclon Idealarc sp 200
    Thermodyne Econo-pak50
    Victor O/A tourch.
    Jan 2007
    105
    Post
    it's a wierd product tho to all the steel yard around here . I can get 2.5'' by 1/4'' wall seemless tho, but some customers want the 2.5'' class 5. In my opinion if you need that much weight you may as well use a pintle hook and lunette eye.
    Jorgensen MFG.
    www.ehhitch.com
    Salem ,Ohio
    3,654
    Cool
    Too bad you don't want 4" sq seamless, i work across the street from the place. They custom make any size but i bet it ain't cheap....Bob http://www.timken.com/products/alloy...ures/kelly.asp
