    5
    Red face Bought some old, but low hours,equipment,...
    Newbie here. Just bought a Trailblazer 250G with an HF box and an old Spoolmatic 3 gun.
    Question #1: Does the Spoolmatic plug into the High Frequency box, HF-251D-1?
    Question #2: Is a spool gun and a wire feed box two different designs for doing the same thing?
    Dwain
    105
    question #1 = i dunno...
    question #2 = it pretty much is the same way of doing things. I see the spool gun as a way to mig weld aluminum tho. But if i had a engine drive i would use a spool gun insted of a box feeder, it's cheaper and jus seems more practical to mee. Can you get extentions for the spool guns tho? you know?
    Jorgensen MFG.
    argonweld_bjorn@hotmail.com
    www.ehhitch.com
    Lake of the Ozarks MO
    3,446
    Unless that "box" is a WC-115 which is the box you need to run a spoolgun on a trailblazer. It runs the positive lead into it and runs of of the 110v circuit also. It should never be ran thru the freek box tho.
    N.C.
    362
    The HF box is for TIG.....nice find...
    Good Luck,
    Mike
    George W. Bush was saving your butt whether you liked it or not!
    HH210 with SG
    Do not hook up the spoolmatic to the hf box,the spoolmatic was never designed for or needed high frequency.The older spoolmatic 3 will be a direct hookup to your engine drive 14 pin,no extra box needed.The newer spoolmatics need a w115 or whatever box.Just trying to help.
    Trailblazer 302
    Suitcase 12vs
    spoolmatic 3
    victor journeymanx2
    esab multimaster260
    esab handy plasma 550
    Makita grinders
    Lathe
    21cfm honda compressor
    f350 superduty 4x4
    Lots of bills lol
