Results 1 to 10 of 14
    Jul 2007
    115
    Default Welding Grade 5 Or 8 Bolts
    Can You Stick Weld Either A Grade 5 Or Grade 8 Bolt At The Head To Something Without Losing The "hardness/temper"?
    I Asked This On The Hobart Forum But Differently.
    One Suggestion Is To Use Cold Roll Rod, Thread It, Then I Guess I Can Harden It With Harris's Flame Hardening Compound.
    I Am Having To WELD A New Thread Onto Forklift Anchor Eyes Which Attach To The Roller Chains Which In Turn Do The Lifting.
    Clark Lift Wants $300 Each For These 8" Threaded Anchor Bolts And That Is No Joke. Can't Find Them Anywhere.
    Any Help, Much Appreciated!!
    John
    Feb 2005
    N.E. SD
    1,381
    Quote Originally Posted by JOHN1
    No.
    Can you fabricate some without welding?
    Jul 2007
    115
    No, Because The Head I Am Trying To Weld To Is For The Roller Chain.
    1,258
    welding hardened bolts is a no no, i plug welded some grade 8 1/2" bolts to mount a vise to a bench. when i went to tighten them i barely got them tight and they pulled right out breaking flush with the welded part.
    making forklift parts is a big risk they take alot of stress, i would machine it if possible out of something better than 1018
    The one that dies with the most tools wins
    If it's worth having, it's worth working for
    650
    I know $300 seems a lot but what will a trip to ER or worse cost? I'm all for saving money but this doesn't seem like the one to do it on. God lick whatever you decide.
    Dennis
    Thermal Arc 185-TSW
    Millermatic Challenger 172
    VictorO/A
    Atlas Craftsman 12 by 24 Lathe
    Esab PCM-875
    Wholesale Tool Mill-Drill
    Aug 2004
    guilford, ct
    858
    you could machine the part out of annealed 4140 or simmilar and have it heat treated..hmmm May be cheaper to spend the 300 on a guaranteed part.
    Trailblazer 302g
    coolmate4
    hf-251d-1
    super s-32p
    you can never know enough
    lramberson Guest
    Liability is the reason for the 300 bucks and they know you have to go to them to get it
    4,469
    Hardened bolts are welded all the time, they actually weld very well. Bolts are not carbon hard, they are low carbon low alloy, very similar to welding rods. Is there any heat treating to a grade 5 bolt or is it the material its made of?
    163
    Sberry, I believe the higher grade bolts are of a better alloy. If they were hardened plain carbon steel they would be breaking like carbon taps
    Welding something hardened/heat-treated like drill bits is best dun with silver-brazing. Silver has a very high tensile strength just as long as it doesn't get hot while in service. The low melting point doesn't affect the hardness very much. If you do try welding something heat-treated you will have a small area around the weld where the hardness has been screwed up.
    Do you have a pic of the job???
    4,469
    I guess my question is,,, is there any heat treat to a grade 5 bolt?
