Results 1 to 10 of 11
Thread: nice rack
    N. GA
    9
    Default nice rack
    Just built a rack to organize all my welding stuff. I've got the mig, tig, tig cooler and plasma cutter, plus oxy, acet, argon, and mix tanks on board with chain retainers. I built a box for 4 50a receptacles , 1-20a 220, and 2-120v for all the power, and a helmet box up top. Tired of having everything under foot. 4 big cable/hose hangars too. This has really helped clean up a tangled mess. Anybody build something similar?
    tom
    Oklahoma City, Oklahoma
    304
    only one question....do you have any problem with stability? I realize a lot of the weight is low, but it seems like it could still be a little top heavy with that much height, on a small footprint. Just curious. SSS
    Alberta Red Deer
    373
    thats kind of what i was thinking
    N. GA
    9
    It is pretty stable... the real heavy weight is low. If I tried I could push it over, but no incline or bumps at all here, all smooth concrete and it doesn't get moved around so much.
    t
    Columbia SC
    165
    nice rack ... great equipment...
    Jim
    Feb 2006
    North Platte, NE
    102
    I like the idea but would probably spread the frame out a little. Thanks for the pictures.
    Feb 2006
    Santa Clara, Ca
    68
    Nice work, looks great.
    But it wouldn't work here in earthquake country
    304
    Very nice, I really like the way it looks. Id say if you had the top spart in the front and all the taks in the same spot it would be less likely to tip but other then that its very nice.
    Looks good....but id have to say the center of gravity is a little high and looks like it would be prone to tipping over..I think I would have made it half as tall. But if it works for you, then thats all that matters...
    304
    Quote Originally Posted by jeli View Post
    ...but no incline or bumps at all here, all smooth concrete...
    t
    Lucky dog...our shop has two ramps, and it's own version of an obstacle course. BTW, N GA is a great place to live. I worked in Alpharetta/Roswell for five years, and still go back a couple times a year. Ever eat at the Smith house in Dahlonega? SSS
