chris,
thought I had posted this already... ??? brain fade
this is a 250 mounted on single axle with mounts for bottles
a 'jobox' welder box will be on the front.
still got to rig with tail lights, work lights and fire extr.
axle is a rear from a Mercury Villager van... think it's actually a Toyota axle that merc specs... added helper coils but not for weight... the leaf springs were a little too 'springy'.. the coils cut down on the bounce when traveling...
hope it helps
john
Results 11 to 20 of 30
12-05-2005, 06:28 PM #11
- Sep 2005
- 21
12-05-2005, 07:10 PM #12
- Dec 2005
- New Braunfels Texas
- 13
John;
Thanx for the information and pics. That gives me some better ideas than what I originally had.
ChrisChris Snyder
12-05-2005, 09:09 PM #13
- Dec 2005
- 2
welding trailer
Chris, I think I have finally figured out how to attach pics. I have a bobcat 225, it also wieghs about 560lbs. The single axle does not have any trouble hauling the machine and all the other things I have on it. The trailer frame is built out of 4" channel with 3/16" plate for the floor. For the boxes, I had a sheet of 1/8" plate sheered & broke into L-shaped pieces. I used the floor of the trailer for the bottom of the boxes. I made the lead/ext rack the way I did to prevent shaking. I cut holes in the floor to recess the bottles 4". Let me know if you have any questions.
Good Luck, JasonLast edited by meadweld; 12-05-2005 at 09:15 PM.
12-06-2005, 09:38 AM #14
just make a skid for yer truck
drops in in 5 minutes
cant see much, but thats the beauty
tanks hidden
cables rolled up
tools locked uppast welding instructor
CWI
business owner
12-06-2005, 07:26 PM #15
- Sep 2005
- 21
Originally Posted by snyder253
chris,
I've got some rough dimensions if you're interested
j
12-06-2005, 07:31 PM #16
- Dec 2005
- 13
[QUOTE=jniolon]chris,
j[/QUOT
Yes I will take any advice that I can get. By all means, send them when you have a chance.
Thanx
Chris Snyder
12-06-2005, 07:46 PM #17
- Sep 2005
- 21
sketch
there u go
12-06-2005, 08:05 PM #18
- Dec 2005
- 13
Thanx John for the measurments, I plan to use that as a starting point, with some minor changes, for racks and toolboxes, etc. Hopefully after the first of the year I will be able to post some pics. of my new trailer and machine.
Once again ThanxChris Snyder
12-07-2005, 01:55 PM #19
- Nov 2005
- 9
Here's a pic of the welding trailer I'm in the process of rigging out. I had the 5 x 8 trailer built. I welded up the stand for the Trailblazer and since the picture was taken I've added reels for the leads and chains for the tailgate. I need to add bottle racks. I raised the welder up so I could load pipe or supplies and not hit it. Any suggestions for additions are appreciated.
12-09-2005, 06:22 AM #20
- Dec 2005
- Tejas - home of SRV!
- 13
Just a side note...keep in mind where you're gonna be goin' with your trailer and the environment it'll encounter. No sense in doin' all that work only to watch your new trailer bouncin' around in the rearview because of cheapo tires that just self-destructed. Leave the passenger car tires on the car, invest in some good trialer tires. Mount a spare somewhere on that puppy too!
Is the wheelbase long enough? Yep, you've seen those guys flyin' past ya on the freeway with their little HF trailers at 95mph about to lose it huh?
Watch your mounting points for bottles etc. Don't skimp on bracket thickness or one pass with a wirefeed. Everything might seem dandy when it's sittin' there in the shop and you're buddies will vote you cool-dude-of-the-month BUT ya need to anticipate real-time conditions such as bumpy roads, ruts in the field...you get the idea. Things can get un-funny real quick in an auto accident too. Will those bottles stay there in a somewhat hard fender bender? Can't depend on gravity for everything LOL!
Don't mean to be a neysayer, just tryin' to keep a few points out front. Maybe a someone would like to start a "safety thread"?
'birdLast edited by tbird; 12-09-2005 at 06:25 AM. Reason: spellin'
