Results 1 to 8 of 8
    Winnemucca,NV
    4
    Default Dial arc 250 Tig?
    Hi, I'm new to this message board. I'm buying a Dial Arc 250 and am wanting to do some DC Tig. Can someone tell me the things I need to get it going.
    Morris, Il
    7
    Smile
    Check out the answers that tdkkart gave me. I am in the same situation as you with just purchasing a Syncrowave 200 last week. My post is titled Syncrowave 200 setup and is 6 below your post. as of 8:40 PM central time.
    Alberta Red Deer
    373
    talk to ur local dealer for the proper equipment to out fit your machine. but i would find the right torch for your machine then u need to get some argon and regs.
    Winnemucca,NV
    4
    This should work! Now can use my 75/25 mixed gas from my mig, or do I need argon?
    Alberta Red Deer
    373
    you need to run strait argon with your tig or a helium mix.
    Bertram TX
    157
    Default Dialarc
    Is that the DialArc HF? Otherwise you'll need an arc starter to go with that setup. I've got the Dialarc HF at work with a radiator cooler and it's a pretty solid machine for TIG. Also, you can still dowload the manuals off the Miller website. Good luck!
    Matt Adams A&P, IA
    Trailblazer 302
    Dialarc HF
    Georgetown, TX
    19
    Quote Originally Posted by dds78910 View Post
    Hi, I'm new to this message board. I bought a Dial Arc 250 and am wanting to do some DC Tig. Can someone tell me the things I need to get it going.
    I recently bought a used Dialarc HF off ebay and have spent a fair amount of time getting it set up to go. All I got was the basic machine with a burned up torch (I didn't know the torch was bad when I bought it). Not being a welder I was in for a little shock at the cost to get things going.
    I bought a Weldcraft water cooled torch
    Argon Bottle (80 cu ft)
    Flow guage/regulator
    consumables.
    I also had to rewire my compressor receptical outlet and wiring for 6 guage and 50 amps. For the time, I'll just unplug the compressor when I need to use the welder.
    Additionally, I had to buy some adapters to hook up a hose for water cooling. Initially, I just used the water from a hose bib and used a long drain hose and ran it outside the garage.
    Again, I've never Tig Welded before but what little gas welding experience I have allowed me to at least do a couple repairs on some stainless. They weren't necessarily pretty but they hold.
    I just finished building a torch cooler that I'll post under a different topic.
    Does your look like this?
    Winnemucca,NV
    4
    The dialarc is my brother inlaws and he was going to sell it to me for a good deal. But this weekend I changed my mind and just bought a miller econotig. So that way I should be able to do all the stuff I want to do and not worry about needing anything else. I bought the machine and the bottle of argon for $1800 after tax.
