Results 1 to 2 of 2
    B. C. Canada
    10
    Default first job taken on
    this was a sub contracted job as the person didn't have time to do it as when it needed to be done this is the 6th time that i have done this type of work since i was 12 yrs old. this one was done with rented 300amp lincoln's & ln25 wire feeds---- wire 5/64 innershield - have more pics need to resize though
    Sears 230 AC welder
    Westinghouse MK250 AC welder
    Delvilbess Air compressor
    1997 Dodge Cummins Clubcab 3500 4X4
    11 HP Air Compressor 30 Gal
    Miller 302 TB Kolher Eng
    K4 ArcAir Gouging Torch
    Hobart Wire Feed cc/cv
    Hobart Hefty Wire Feed cc/cv
    Harris Oxy/Propane Torch
    Miller Syncrowave 180sd Tig
    Dec 2005
    Dallas, TX area
    267
    Default Looks good.
    Keep working and learning. There is some knowlegde to be gained from every job you do no matter how long you do it. Congrats on your first job!!!
    Triggerman
    Ammonia refrigeration tech
    Millermatic 180 w/Autoset
    CST-250
    HF-15 High frequency
    XR15 w/Push-Pull Gun
