WELL THERE IS NOT NO SHADE HERE IN TX. THE LAST COUPLE DAYS. I BEEN MAKING SMALL DIAMETER PIPE TEMPLATES 90/45 DEGREES JUST TO SPEED UP PRODUCTION OUT IN THE FIELD. METAL GEEK HAS A PRETTY GOOD PROGRAM THAT WILL PRINT OUT THE PATTERNS , I TRANSFERED THEM TO PIPE WRAP MATERIAL , WORKS REALLY WELL.
STILL CONFUSED ON HOW TO FIGURE OUT HOW TO DO A 45 SADDLE PIPE TO PIPE. DAN HOPPER HAS A SITE THAT MAYBE EXPLAINS IN PHILADELPIA LAWYER MATH OR ROCKET SCIENTIST MATH. I GUESS I WILL STICK TO THE CUT TIL IT FITS WAY. I KNOW YOU CAN BUY THESE TEMPLATES AT YOUR LOCAL WELDING SUPPLY,BUT THE WEATHER IS NOT COOPERATING TO DO ANYTHING OUTSIDE , IF ANYONE HAS ANY SUGGESTIONS LET IT RIP!NEVER TO OLD TO LEARN NEW TRICKS OF THE TRADE
SAN ANTONE I AM IN THE WHARTON AREA.![]()
Results 1 to 10 of 18
Thread: Pipe Templates
01-17-2007, 07:44 AM #1
- Jan 2007
- 53
Pipe Templates
/22x45 concrete slab with 2 overhead cranes(trolley style with electric hoist, huge shade tree to weld under
33x33 enclosed shop when its to cold or windy outside
miller 210
miller 875 plasma
victor oxy/accet
unihydro 45ton ironworker
miller 180 tig
ole lincoln ac/dc buzzbox
milwaukee power tools
and everything in between
2007 trailblazer 302
Bailiegh 210 miter saw-2008
Beer Fridge
6000# cat forklift
36" port-a-cool fan
Dake G-75 Belt grinder
3035 Spoolgun
01-17-2007, 11:27 AM #2
Wharton, huh? I know where that is. Have family in the Lake Jackson area.
On pipe 45's I just use a saw and make a 45° cut on the pipe, then just take a round notch out of the long ends. As long as it does not have to be perfect, that will work fine. Sometimes there is a gap that will take some filling. Precise placement can be difficult with this way, but it can be done.Don
'06 Trailblazer 302
'06 12RC feeder
Super S-32P feeder
HH210 & DP3035 spool gun
Esab Multimaster 260
Esab Heliarc 252 AC/DC
01-17-2007, 03:41 PM #3
TubeMiter works good too. You can download it from the following link:
Tube Miter Link
Hope this helps...
01-17-2007, 04:31 PM #4
You could buy a Joint jigger, its like a vise that holds the pipe at what angle you want and it has a drill chuck where you attach a hole saw of desired size
then power it with a hand drill. They work well on thin pipe and on thick pipe if you have a good hole saw. but most hole saws are only good for mild steel or aluminum. dont last long on stainless. If you would like one you can find them alot of places ebay has them usually sell for about 65.00
01-21-2007, 10:02 AM #5
- Jan 2007
- Pensylvania
- 16
One way is to hold the pipe you are saddling 45 deg. to the base pipe, using a pair of divders and a soap stone attached to it, follow the contour of the base pipe with pointed leg of the divider while marking the saddle pipe with the soap stone leg. this works with same sized pipes or different sized pipes, and different angles. after you make one miter you can transfer that to template materials using center lines.
01-21-2007, 12:27 PM #6
Get a pipemaster, works for any angle you want.
Pipemaster website
EdLincoln Tombstone 180 AC
Hobart Handler 120
Millermatic 210
Old Harris O/A setup
Victor SuperRange II on propane
Hypertherm Powermax 380
Ryobi 14" chop saw
Milwaukee Sawzall
A bunch of grinders
A lotta other tools
Check out my website at: Ed Eldridge's Race Page
01-29-2007, 07:20 PM #7
- Jan 2007
- Pensylvania
- 16
Now thats slick.
01-29-2007, 07:44 PM #8
You could use the cut until it fits and then wrap it with paper and cut it out.....then transfer the pattern to some sheet metal etc.......I saw that one on Xtreme 4x4.
Good Luck,
MikeGeorge W. Bush was saving your butt whether you liked it or not!
HH210 with SG
02-18-2007, 05:16 PM #9
That Pipemaster is slick, but a 12 inch is 700 clams.....I have used the 2 inchers, they are handy.....too bad you can't just buy a bag of pixie dust or something and go wala....can anyone post pictures of the divider way???? I am still kinda unclear on what was written, I once bought on of those all purpose wraparound gizmos, but lacked the grey matter to figure it out. Thanks, Paul
02-21-2007, 10:06 PM #10
- Feb 2007
- Near Dallas, TX
- 214
Here's a template maker that I built. Print out the 'ruler' to measure your tubing, then enter the tubing sizes. The printed ruler compensates for the scaling of your printer.
http://nanosleep.dyndns.org/tubing/
Hope this helps
-Andy
