Page 1 of 3 123 LastLast
Results 1 to 10 of 21
    Jan 2006
    london ont canada
    96
    Default Tig bead good or bad
    I am working on my tig welding and have been trying different settings on my dynasty 200dx and have been changing my technique to see if i can produce a weld that looks something like some of the welds posted by experienced welders on this forum and my tig welds started getting lines in them. I wasn't able to take a picture of the welds but found some pictures on the we that look something like mine. If you could tell me what I am doing wrong that would help and how would I fix this problem
    Southern B.C.
    99
    Those lines aka crowsfeet on the bottom bead are from excessive heat, either let up a lil on the pedal, speed up, add more filler or all of the three! Good luck. Carl
    Jan 2006
    london ont canada
    96
    I find that when i am tig welding steel I either end uo with a weld that has those crowfeet or I end up with a weld that has a lot of ripples. I get the usual ripples from where I dipped the filler metal and then i get ripples from where I moved the puddle forward. thats for the help so far and I am wondering I anybody knows how to get rid of those little ripples from where i moved the puddle forward.
    Jan 2006
    london ont canada
    96
    I managed to take a some pictures and hopefully you can see what I mean about those small ripples caused by moving the puddle also in one of the welds the crater is bronze and i don't know why. For all of these welds I ground the surface to shine and poished it with scotchbrite. The filler metal was er70-2 so I don't know what caused the problem. My shielding gas is set at about 12 cfh. Any comments about the welds and what you think would be great.
    Dec 2004
    147
    Quote Originally Posted by 3faze
    These look much better than the first. I don't know about the bronze dimple at the end, but I have noticed that when I keep the torch moving and dip quickly, I get the rippling effect which is perfectly fine. If I do more of a move and pause with the torch and make a bigger dip (but less frequently), I get the stack-of-dimes look.
    1,258
    the bronze spot is contaminants (i think) they ride on top of the bead until you finish it then it has nowhere to go so it lays on top. you can have the surface very clean and still get it i believe it comes from the material itself. for the ripples try stopping when adding filler, then advance a bit stop and add filler, advance stop add, advance stop add...........you get the picture. before long you won't even think about it, it will just happen. your welds are definatly improving, keep up the good work! just a tip, while practicing try to run your beads as straight as possible, it's all part of a sweet tookong bead and better to practice it now than try to "correct" it later on.
    Craig
    The one that dies with the most tools wins
    If it's worth having, it's worth working for
    Jan 2006
    london ont canada
    96
    Thanks once again for everyone's advice
    Southern B.C.
    99
    3faze, thats some sound advice from tigman and Your welds look better! Keep it up. I thought of some additional pointers that might help. After running a bead on a piece of material set it aside and use a different (cooler) piece. Clean Your material with a wire brush until You are satisfied You would eat from it! Wipe Your filler rod with isopropyl alcohol using a scrap of old cotton fabric. When making Your last puddle on a bead,lift your pedal very slowly! Good Luck! Carl
    Jan 2006
    london ont canada
    96
    I am still having some problems getting nice defined ripples because no matter how long I move between each dip or dow much I dip I either end up with lots of small ripples like the second set of pics that i posted or I end up with a weld that looks like the first picture. Does any body have any pictures of stringer beads on 16 gauge sheet metal? I am probibly doing one little thing wrong (I hope) and that is causing problem with me tig welds. When I clean my base metal I wire brush it, then use scotchbrite and then wipe it with a clean cotton cloth. For the filler metal I wipe it with a clean cotton cloth I plan to got and get some acetone some time soon. Any body have any ideas what might be causing the problems. Any help would be great
    1,258
    3faze, 16 ga is tough because it overheats so easily, i assume you are welding hot roll sheet?? if so make darn sure you use a flap disk or equivelent to remove the scale down to the steel color, and make sure it's at least half an inch away from where you are welding. nothing and i mean nothing will make a weld look like crap quicker than scale. mabey you are already doing this if so please disregard what i just said i will try to weld some 16 ga tomarrow and post results....if i rember
