Results 1 to 10 of 18
    12
    Default New to welding, and need LOTs of advice...
    Hey Guys,
    So here is the deal... I am building a homebrewery system, and I will need to do some welding. I should mention now that I know very little of welding, but I am a quick learn.
    So, the basic welding needs e for the stand and the brew kettles/fittings. All will be stainless steel, of relatively small gauge.
    The stand will be built of out of 2"x2" 0.120 stainless sqaure tubing. Follow this link for an immage of something similar to my goal:
    http://www.alenuts.com/brutus.htm
    The kettles will also require welding of stainless couplers as seen in the above link.
    So, from what I have read, TIG is the way to go. That said, what do you pro's think is a good entry level TIG setup? Any ideas on whether to buy new or used, and if used, where is a good place to look.
    WRT my wleding ability, I will probably trade some beers with a few local guys to get some instruction, and/or take a class at my local comunity college. I don't mind investing in the equipmant, as tools are always good to have, but I also don't want anything that is overkill...
    Ok guys, share you thoughts!
    Thanks,
    Bryan
    i would say a used tig would be the best way to go but more expensive and a longer lerning curve. as its SS you only need a DC unit so e-bay would likely net you what you want.i would stick to a small inverter type welder as it will alow you to use standerd houshold power where the transformers will require 60+ amp 220V circuits, with the exception of stove you are not likely to have that kind of power in your house.
    a small MIG would also work with a try-mix gas also and would be easyer to lern but not as nice looking welds. eather way you will need to be able to back gass it be it with a 2nd tank or a T and 2 gages.
    good luck and have fun.
    12
    Thanks for the information....
    Would it be possible for you to suggest some models to keep an eye out for on ebay and elsewhere?
    Thanks,
    Bryan
    Jun 2006
    MN
    12
    where you at? i got a Lincoln(i know i know i dont want to hear it i got it at a discount lol!) v160-T a nice portable tig machine, i went to lincoln welding school, im 19 and i know what im doing, if you dont live to far from me im willing to travel, i got a nice back purge set up going with it too, which is very key when it comes to stainless. so yeah just post the state and town and like i said, if not to far im willing to travel
    edit: this is an inverter just like fun4now was saying so it runs off a normal 110v outlet or whatever voltage they are(mental block right now lol)
    Hey good to know you are not afraid to jump in and give it a shot! You might find some good advice from a weld shop that does work for food prep /services co's. They usualy do alot of repair and fabrication work on stainless and could probably point you in the right direction. By the way toss one down for all of us when you get her up and running. Pics greatly appreciated as well.
    the maxstar 150 would be the miller choice but i have seen some others out there, just dont fallow them. just about any of the little inverters should do fine. if you want to keep it and get into more welding i would get a good brand name even if it means saving up for a wile.
    it took me about 3 years to save up to get my TIG but i wanted AC/DC so they run a bit more and i have a realy low income so that didnt help. if its a one time thing renting might be the answer, look into a weeks rental with gas and see what you are looking at. no point buying if its a seldome used thing, it can add up fast.
    this would do what you need nicely.
    http://www.millerwelds.com/education...read.php?t=745
    plug it in and weld at the kitchen table if ya wanted.
    Suffield, Ohio
    344
    I agree with Fun that the little Maxster 150 is a good choice, as long as you don't do to thick of material or aluminum.
    12
    Thanks Guys,
    I really appreciate all the help and advice...
    So, I currently live in NYC, but will be doing most of the fabrication at my fathers home in CT. Anyone in the hood? I've got beer!!!
    The smaller units do look appealing, and the price seems tollerable. I will keep my eyes open n ebay and around to see what crosses my radar screen.
    My most important question is, do the smaller inverter type rigs have the power to weld the 11 gauge stainless, along with couplings and pipe?
    I thought about renting, but I like tools, and I don't mind investing in good equipment. I also plan on putting together a good smoker someday in the future, and I'm sure there will be other projects that will come up. Also, I like to be able to work for others should they need the help...
    How often do these units show up on the used market, and what accessories are suggested for the initial purchases?
    Thanks Fellas,
    Bryan
    the 150 has all the acesorys with it, or the one in the link dose any way. if you buy it new you need to get the contractors kit to get all the goodies needed.
    the 150's come up used now and then but the ac/dc type are a bit harder to find. the 150 will do a little over1/8" with no truble so the 11gage is easy.
    if you are investing in the tool to keep a good namer is recomended not the HF version.
