Page 4 of 7 FirstFirst 1234567 LastLast
Results 31 to 40 of 65
  1. #31
    Oct 2006
    642
    Quote Originally Posted by garybdavis View Post
    I know I couldn't justify the expense, but nice tools and equipment is my one vice.
    Ya know, I bet there are many hobbyists who have this same vice. I know I do, we just got into welding and are acquiring the best that our money can buy, within reason. ( last 2 words added in case wife reads this )
    We are going to be building a nice utility trailer, and it will be built like a tank. For me with my inexperience the first trailer will be a long term project, but I have watched some excellent trailer being constructuce from raw material to rolling down the road and I know what it takes.
    I gotta say though, however you classify yourself that trailer is EXCELLENT.
    You may not make a living from welding, but I bet you could.
  2. #32
    Aug 2004
    Milan Michigan
    1,863
    To Harco Sparky, Gary did a buitifull job on his trailer and am sure he made it how he feels he needs it,
    I built one like it about 10 years ago for my Miller Big 40.
    Whenever I build something like that I draw it to scale on paper so I can catch any mistakes including how much space between cables etc.
    Gary has a hitch on the back of his trailer for what I will assume to be a vise mount.
    I would encase the tanks and gages inside inside there own roll bar so that I could leave them on and in the event of a roll over the guages would not get ripped off the tanks.
    I would also make a rack to hold a couple different size ladders and additional space on the rack to haul some longer pcs. of steel.
    When making a spot for your vice remember that many time you may put some thing long in it to grind, it is often handy to have a rest to hold the other end of the pipe even to the bottom jaw of the vise.
    I really like the way Gary hid his lock inside that pipe, I caution him to make sure he has extra keys for that lock because he will destroy his box trying to get the lock off if he loses his key.
  3. #33
    Dec 2005
    Lodi, CA
    1,495
    Somehow I missed this one earlier????
    I think the planning and engineering here were excellent, and the finish work is top-notch.
    I see the hitch receiver on the back of the trailer, some think it's just for a vise, I also see a trailer wire plug back there, you set it up to haul another trailer behind it?
  4. #34
    Mar 2006
    e-town, ky
    382
    very impressive work Gary, extremely proffesional job.
    marty
    Miller Synchrowave 250
    OTC 300DM with external wire feeder
    Miller XLi Dale Sr., fibre metal hoods
    Metaltek of Ky. Inc.
    Home of the Stephensburg weld
  5. #35
    Jul 2007
    campbellsville ky
    953
    what about it gary???????????
  6. #36
    Jan 2007
    393
    Great work. dont call youreself a hobbiest anymore
    You and Fun for now should team-up.
    Put some feelers out....see what the market has to say.
    great craftmanship, attention to detail.Youll blow em away
    GOOD LUCK
    Dave
  7. #37
    Apr 2007
    348
    The hitch on the back is for towing another trailer or mounting a vice. I put a connector back there for hooking up trailer lights just in case I take it on the road with another trailer hooked up. Most likely, this would be my trailer mounted Ingersol Rand air compressor for arcair applications.
    I did a scaled CAD layout complete with dimensions before I started construction. I also did front-to-rear center of gravity calculations to insure the tongue weight would be balanced. If anyone wants copies, email me and I'll send them to you. The CAD will be in PDF format so you wonít need special software to view them. The center of gravity calculations are in an Excel spreadsheet.
    Davis.garyb<at>gmail.comxx is my address. Youíll have to insert the @ symbol in the proper place and remove the xx. I write it like this to keep the computer trolls from pulling it off this forum and adding it to their spam list.
    There are eight-ways-to-Sunday to lay out a welding trailer. This one doesnít have it all, but I like itís simplicity. It rarely leaves the farm and will spend most of its working life welding fence bracing, corrals, etc.
    BTW, Thanks for all the kind compliments.
  8. #38
    Apr 2007
    348
    One last thought. My wife and kids took one look at the paint job and instantly starting calling it the "smurf-mobile". I had this blue tint to my hair from the overspray when I came in from painting it and they started calling me "papa-smurf". When I go out to weld with it, they call me "welder-smurf". When one of my buddies calls to borrow it, they ask the "smurf-mobile". I thought the paint was a good choice, but man...
  9. #39
    I hear tell that all Smurfettes just love blue machines and blue welders.
  10. #40
    Oct 2006
    South Central Texas
    20
    Hi Gary,
    Great work! Looks as if you will be moving down in our neck of the woods.
    Peace,
    Chaz
