Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 51
Thread: Flash Burn?
  1. #41
    Nov 2007
    Central Idaho
    205
    Quote Originally Posted by R W View Post
    Cold tea bags can be used to help relieve pain if nothing else is available.
    There should be a cream or drops on sale at chemists for this problem.
    Have been told a quick direct look at the sun, on receiving a flash will
    prevent flash burn,I have done this many times and have had no problems.
    Looking at the reflection of welding of a bright surface,like corrugated
    iron can result in a bad flash burn.
    R W
    "A quick direct look at the sun...will prevent flash burn" you are a raving idiot! That is like saying that if you get a slag burn, you should just hit it with a blast from your O/A torch. Like more burn will take away the burn! The folk remedies posted here are downright scary! Get an opinion from a qualified professional!
  2. #42
    Oct 2008
    Oregon
    193
    An old friend told me about his always carrying the head of a ball peen hammer on his belt.
    When his eyes got hot he would put the flat end against his eyes to soothe them.
    Millermatic 211 AutoSet w/MVP
    Century 110 volt 90/110 MIG-Gone to my son, in Texas
    Victor SuperRange OA
    Milwaukee Cold Cut Saw
    Milwaukee Portable Deep Cut Bandsaw
    Milwaukee Hole Hawg
    Jet Horizontal/Vertical Bandsaw
    Jet MD-18 Mill Drill
    Orbit Drill Press
    12 Ton Floor Press
    2002 E-350 V-10:
    1983 F-150 4.9L 6
    2004 Honda ST1300
    2007 Suzuki LTA400F Quad
    1997 Suzuki DR650
  3. #43
    Jul 2007
    Carroll County, Maryland
    108
    Quote Originally Posted by TomVeatch View Post
    You don't need to shut your eyes tighter - you need to wear your helmet. Don't get caught up in some kind of macho nonsense about not using safety equipment. "Macho" don't help you carry a white cane!
    Quit watching those stupid TV shows where no one wears a helmet. Don't do as they do do what's right for your eyes. Those type of TV shows should be banned unless they are using the proper safety equipment. Wear that HELMET!!!
    The definition of courage. "It's when you know you're licked before you begin, but you begin anyway and you see it through to the end no matter what." From "To Kill a Mockingbird"
  4. #44
    Sep 2004
    Buffalo, NY area
    37
    Quote Originally Posted by mikeswelding View Post
    Plus your really screwed if your working the night shift or it's a cloudy day...then you have to call in sick...tell them your waiting for a sunny day so you can go outside and stare at the sun to relieve your flash burn...
    Tom
    Dynasty SD
    Millermatic 130
    "Too Bad Those Who Know It All Can't Do it All"
  5. #45
    Default flash burn
    i have been a welder for some time now and gotten flash burn 3 times twice when i first started and once welding next to other people on a line with no curtain. it feels like sand is in your eyes and burn like **** but what i use was potatoe slices, believe it or not it really does work. it draws the burning feeling from your eyes. just my 2 cents.
  6. #46
    Mar 2009
    Michigan
    138
    Post burning eyes
    In my early days of welding (back in high school), I did not like to wear a helmet when tack welding. I was getting flash burn to extreme levels and often. I would wake up in the morning and not be able to open my eyes due to all the hard crusted eye-goobers on my eyelids. I am thankful i did not do any Permanent damage! One of my methods for healing was to put antibiotic ointment on my eyelids…it is made for minor burns. Found that it would heal in about 24hours. I finally got smart enough to wear a helmet. Helmets are made for a reason….Where them!
    Miller Syncrowave 200
    Miller Spectrum 875 Plasma Cutter
    Miller Milermatic 135
    Ridgid Drill Press
    Ridgid Chop Saw
    36" Metal Break
    Harris Toarches
    English Wheel
    Ingersoll Rand, 18.1 cfm Compressor
    30 gal. Sand Blaster
    Planishing Hammer
    150lb Anvil
    10" Swing Logan Lathe
  7. #47
    Jan 2008
    In wal-mart
    460
    Forget those quack remedies, or old welding bushman tricks, and get yourselve's some naphcon eye drops to immediately alleve the pain and burning, and then go out and get yourself some common sense about welding without a hood.
    If you want peace, be prepared for war!
  8. #48
    Deltaville, VA
    2,239
    Just keep in mind that the only thing I can think of being worse than dumb, is being dumb and BLIND.
    From some of the comments here, it sounds like a few have the first down pat.
    Syncrowave 250 DX Tigrunner
    Dynasty 200 DX
    Miller MM 251 w/Q300 & 30A SG
    Hobart HH187
    Dialarc 250 AC/DC
    Hypertherm PM 600 & 1250
    Wilton 7"x12" bandsaw
    More grinders than hands
  9. #49
    Mar 2009
    Papillion, Nebraska
    19
    Watched my Granpa weld one day when I was 6 or 7. That night my eyes were like they had knives stuck in them and had the worst headache ever. Folks had to take me to emergency room to get pain shot. Learned the hard way. Yeh! I still tack every once in awhile without the helmet....lazy.
    My biggest thing is grinding dust. My eyes are in misery after a good day of grinding. Even use a face shield. Dust just drifts up and under or the grit richochets up under it. Looking for some desert goggles that fit tight and are dust proof. I have a powerful magnet out of a computer hard drive that I keep around has saved me a few times, but a chance it's a carbide grit too.
  10. #50
    Oct 2009
    Exclamation
    The majority of welders get flash burn due to indirect exposure.
    UV radiation (the cause of the whole problem) bounces of from walls, surfaces etc. etc.
    Some materials cause much faster flash burn then other materials.
    Copper (brass) and Aluminium are some of the worst.
    Never think your safe when you stand in the area where there is some welding going on.
    Also a lot of welders are still using the wrong grade of shades.
    Flash burn will leave a permanent mark on your eyes.
    Always use the proper PPE and don't take any risks with your eyes.
