Results 1 to 10 of 14
    bart2004 Guest
    Default mig welding exhaust tubing
    i have not been too successful in welding tubing. either i burn holes in the interface or if i lower the heat, the weld is poor. tubing is standard .06.
    any experiences appreciated.
    i will be fabricating the complete exhaust from the exhaust manifold exit down.
    6
    What is the welder setup, What welder are you using, what is the size and type of wire being used, Flux core or Gas being used?
    Example: I have a MillerMatic 175 and use gas mix of 25% co2 and 75% argon. My wire is size 23 2Lbs. spool of AWS ER70S-6 MIG Wire. #24 would work aswell if need be. Home depot carries Lincoln 25 AWS ER70S-6 which is an all around universal wire for most DIY folk. Depending on whether or not the tubing is galvinized or aluminized I may gently sand\grind slightly bevel the end being welded. Using the #23 wire I set my welder to 3/70 for tacking and 2/70 ish to fill in between tacks. I don't use flux wire indoors and its likely to burn through thinner metals.
    I used 23 to fill in my dodge ram west coast mirror door holes when switching back to conventional mirrors and didn't even need to heat sink the back. I short I found that using GAS mix with 23 wire works best on thin metal 16-24 guage. where structural integrity isn't life or death.
    Miller Dynasty 200DX
    MillerMatic 175
    Miller Spectrum 375
    Broco PrimeCut PC/OTC-20
    Oct 2005
    vancouver bc
    518
    you can do it with mig but i dont reccomend it . if you do do short little beads so as to not burn through make sure you have a tight fitup as any gaps are just begging for problems .
    Miller aerowave full feature
    Lincoln power mig 300 with prince gun
    dynasty 200 dx
    lincoln sp 135 plus
    302 trailblazer
    s22p12
    powcon starcut
    cp 400 metal spray
    I built the complete exhaust on my '99 Ram using my MM210 with no problems.
    I'm running Ar/Co2/O2 trimix with .030 70-s6 wire. I got good welds, no problem.
    Langley BC Canada
    4,635
    It is definitely possible, just takes some set-up and practice. I routinely weld 16 gauge (which is pretty close to your .06), using .030 FC and no gas. Not saying go running out and buy FC, just that with practice, you should be able to do it with what you have to work with. Good luck
    Mar 2005
    Dayton Tennessee
    514
    Quote Originally Posted by dandimand
    Why do you recommend not using MIG?
    The local muffler shops ALL use MIG, & I use MIG on exhaust work at least once a week! The only problem I ever have is old thin & rusty stuff.
    I use a MM185 tap 2 or 3 .030 wire / co25 & wire speed about 55.
    Syncrowave 180 SD
    MM185 with 3035 Spool gun
    1971 Roughneck 1e
    Stars-n-Stripes BWE
    Optrel Satellite OSE
    ESAB 875 Plasma Torch
    Lincoln 200SA Diesel
    O/A Set
    Century 250A/C-D/C BuzzBox
    1.5 kVA Spot Welder
    Phoenix Electrode Conditioning Oven
    Professional Auto Mechanic since 1974
    My own shop since 1981
    Cya Frank
    598
    mig'n exhaust pipe is EASY.
    Texas
    279
    Quote Originally Posted by frank865
    I agree,Frank, my SIL uses this RX at his muffler shop as well as a small mirror to check the top of the pipe to check the pass. Only come-backers are folks needing other systems.
    Good day all
    L*S
    Oct 2005
    vancouver bc
    518
    Im assuming he was talking about building headers not exhaust . Im not sure the gauge of the header material i use but im sure its around 20 gauge maybe 18 at most . this is the mandrel bends you buy . most exhaust tubing i agree can be done with mig as it is thicker. and most muffler shops dont butt weld they have overlaps on tubing with flanging one end larger than the other slip fits etc... . what i have found is to maintain enough heat in the weld without getting cold laps is you can only do short sections or when you turn heat down you get highy crowned welds with cold laps on the restarts .but of .06" i dont see a problem its when you get into the smaller material like 20 gauge which is approx .036" you will have this problem.
    dynasty 200 dx
    lincoln sp 135 plus
    302 trailblazer
    s22p12
    powcon starcut
    cp 400 metal spray
    Mar 2005
    Dayton Tennessee
    514
    His original question was...tubing is standard .06.
    So I don't think he was talking about headers, how about it Bart2004?
    Help us help you...Jump back in here anywhere!
    Syncrowave 180 SD
    1971 Roughneck 1e
    Stars-n-Stripes BWE
    O/A Set
    1.5 kVA Spot Welder
    Cya Frank
