Results 11 to 20 of 26
    N.C.
    362
    Check out the blades here....Bob http://www.mkmorse.com/
    Got to get one of those! That is amazingly fast cutting.Thanks for the link.
    Mike
    George W. Bush was saving your butt whether you liked it or not!
    HH210 with SG
    Jun 2006
    Calgary, Alberta
    377
    There are many carbide tipped blades out there for cutting steels and non-ferrous metals. I've used a 7 1/2" circular saw with the proper blade, 40 to 58 tooth with a negetive tooth offset for free hand cutting aluminum, and other carbide blades designed for steel in cut off saws. They last a lot longer than abrasive blades with the right lubrcant. However, using zip cuts with a grinder makes quick and easy cuts on thin sheet metal or smaller structural sections.
    Townsend, TN
    10
    Smile Thanks too all of you for the good advice!!
    Thanks Welders.........I have used a circular saw with abrasive blades with
    destorted results and very unsafe...you need to wear armour to use one and be
    safe. I really appreciate you men's input...sounds like a good chop saw with a
    metal blade is my best application!
    East Tennessee
    143
    Quote Originally Posted by budbuc View Post
    No! A chop saw with a metal cutting blade is dangerous!!
    There's no way to hold the work being cut, & it'll spin the blade too fast.
    Do it if you want to, but I sure wouldn't do it!!
    Sep 2006
    Wheeling
    169
    I have side tables for my chop saw, it helps holding the metal for the saw. I do the same thing for shear. But larger pieces, I use my Plasma Cutter, it's fast, it you have the stand off on it, it will cut like a dream. Faster than O/A.
    Each technology has it's place, you just have to know how to use them. I learned the hard way a couple of times, but I survived.
    Jerry
    Wichita, Kansas
    107
    Just a request for clarification since I've seen and heard "chop saw" used both for metal cutoff saws and for miter saws used for wood crosscuts. Which definition are you using? If you are talking about a woodworking miter saw, I echo Frank865's caution. Not to mention I wouldn't want to risk several hundred dollars worth of compound sliding miter saw by cutting iron with it.
    Tom Veatch
    Wichita, KS
    Sep 2006
    Wheeling
    169
    This is what a Chop Saw looks like:
    http://www.harborfreight.com/cpi/cta...emnumber=39755
    A Mitre Saw is for cutting wood and in the case of a picture frame shop, aluminum frames.
    Here is a Miter Saw:
    http://www.harborfreight.com/cpi/cta...emnumber=91852
    If you use a miter Saw as a chop saw, it will loose it's quality adjustments and the compound angle will not be that accurate after some useage. The Chop Saw is meant to cut straight down. With the stage or vice being able to be moved on one plane.
    Jerry
    Dec 2005
    Dallas, TX area
    267
    Default Hey Frank......
    Quote Originally Posted by Frank865 View Post
    You want to re-think that?
    Triggerman
    Ammonia refrigeration tech
    Millermatic 180 w/Autoset
    CST-250
    HF-15 High frequency
    XR15 w/Push-Pull Gun
    Lake of the Ozarks MO
    3,596
    If I was cutting aluminum I'd use that wood saw in a heartbeat,,,,but I would use my brain as well. If you have a background using a saw of that style with wood then you'll have no problem but if you are a noobie that sets behind a desk all day and never took a day of shop in school then STOP!!!
    Get some training or yer gonna hurt yourself or worse yet somebody else!!
    Same goes for about any other power tool that will cut metal.
    Wear proper protection and THINK!!!
    Dec 2005
    Dallas, TX area
    267
    Default Morse Metal ***** Saw Blades
    Just ordered my MK Morse Metal devi.l blade for my Skil saw. They are on clearance @ Amazon.com for $38.58 with free shipping available!
    http://www.amazon.com/MK-Morse-CSM72...0?ie=UTF8&s=hi
    Will post back when I get it.
    Happy New Year!!!!!
    Triggerman
    CST-250
