Results 11 to 20 of 21
    Feb 2007
    Central illinois
    98
    Default good link
    thank for the info
    Dec 2006
    15
    Default more info
    I bought a bunch of 1 90 deg (I have an inventory of 1 sq. tubing wont go to waste) Arranging them (see pic) you can make things you cant with a bender. Im not connected to this company, just sharing info with the brethren.
    Miller 301 G w/suitcase feeder
    Millermatic 251
    Miller spoolmatic 30
    Lincoln Ranger8+Diesel, Lincoln SAE 400 amp
    Lincoln SP-125, Lincoln SW 175, Lincoln Pro Cut 55
    Smith O/A, Edwards 75 ton ironworker,
    Grob Brothers Band saw, Hougen magnetic drill
    Aug 2006
    near rochester NY
    9,881
    they could defenetly speed things up for many aplications if you dont mind MIGing them up and dont want pointed corners. cool idea though.
  4. #14
    Feb 2007
    Barriere, BC Canada
    3
    Quote Originally Posted by gunruner View Post
    I would love to see some pics of things you make with the elbows.
  5. #15
    havasu living Guest
    Used a 4" pipe to bend 1/2 stuff and then moved to a 25lb lifting weight to bend the 3/4 stuff. Worked great, no heat either just elbow grease.
  6. #16
    Aug 2006
    near rochester NY
    9,881
    i used a 5lbs and a 10lbs steel wait to bend some stuff also. for solid stock it works realy well, not so good on holow stuff though.
  7. #17
    I do not know how much fabrication can you do, but I have a set of rough plans for a 3x2 and 3x3 square tubing bender I designed for a trailer company that finally got killed by China. You can download the plans from my site and take a look at it and see if you can scale it down. http://www.gottrikes.com/Tube_Bender.htm
  8. #18
    Mar 2007
    511
    Whats up with the link said i have to have a password ?
    welding...its awsome
  9. #19
    Dec 2006
    Wartburg,Tn
    575
    yeah what Weld-13 said
    Inferno Forge
    Chris
  10. #20
    Mar 2007
    511
    Quote Originally Posted by wireburner View Post
    dont think he will be back. he just signed up to advertise his website then left
