Page 1 of 3 123 LastLast
Results 1 to 10 of 21
    Dec 2006
    15
    Default how to bend square tube without bender
    Hello
    I just found this web site I would like to share, I have not tried them yet, But I will soon.
    http://www.quickfab.ca/
    Miller 301 G w/suitcase feeder
    Millermatic 251
    Miller spoolmatic 30
    Lincoln Ranger8+Diesel, Lincoln SAE 400 amp
    Lincoln SP-125, Lincoln SW 175, Lincoln Pro Cut 55
    Smith O/A, Edwards 75 ton ironworker,
    Grob Brothers Band saw, Hougen magnetic drill
    Jun 2006
    Calgary, Alberta
    377
    Thanks for the link.
    Jonny
    Aug 2006
    Suffield, Ohio
    344
    Interesting site.
    Nov 2006
    South of your idea of South Texas
    8
    Default Good on
    hey im going to see there prices on shiping but good find keep them coming.
    Sep 2006
    Wheeling
    169
    Really nice of you to post that link. My next trip to home, I will probably have a box from them waiting.
    Again thanks,
    Jerry
    Jan 2007
    4
    It sounds like the technique that I used to fab up the frame rails on my car.
    you just cut partway through the tube from one end and cut out a triangle with the angle that you want the bend. Then you just bend the tube and weld the butt joint, and you have a bent square tube at the exact angle that you want.
    This technique could be a little tricky to do on slow radius bends though, but I'm sure it could be done.
    Jan 2007
    Arkansas
    56
    Talking
    Thanks for the link. I am going to see if they have a dealer near me
    Jan 2007
    Pensylvania
    16
    Good one, Thanx.
    Default Tube Benders
    I'm into year 4 of my shop build out, and what I hope will be my part-time retirement income.
    Year 1 - Millermatic 135
    Year 2 - Miller Dynasty 200DX
    Year 3 - Miller 625 plasma cutter, TorchMate 4X4 X-Y CNC plasma cutting
    table
    Year 4 - pipe, metal, and scroll working tools
    (http://www.shopoutfitters.com/)
    Year 5 - Lathe and/or lathe/drill/mill
    My point being - yes you can buy pre-bent metal at a premium, or you can buy a tool to do it - look at long term Return On Investment (ROI).
    Steve
    Dec 2006
    Wichita, Kansas
    107
    Quote Originally Posted by bpickell View Post
    Kerf bending? Common woodworking technique to get slow bends. Would leave a poorly prepared joint for welding, 'though, and probably a slightly faceted bend.
    Tom Veatch
    Wichita, KS
