Results 1 to 8 of 8
    17
    Talking Help me design a handle for my cart...?
    Ever have a project that causes you a sleepless night cause you can’t figure out how to do something? Are you the kinda guy that does his best work while listening to his pillow? Me too, and I need the collective engineering power of the forums to help brainstorm a hinge inside a piece of square tubing.
    Let’s toss and turn together now, ready: picture a ladder laying horizontally on the ground. Your mission is to install a hinge in the middle of the ladder so you can lift up half the ladder at about a 45 degree angle while the other half stays flat on the ground. Sounds relatively simple, right…until you realize you want to do the same thing with a piece of square tubing, avoiding welding anything to the outside of the tubing as it must sleeve inside another piece of square, until it’s pulled all the way out past the hinge. Oh, that’s the brain buster!!
    I want to design a handle I can weld onto the bottom of the cart and it stays pushed in under the cart when not needed. The move the cart you pull the handle out all the way, lift it up to a standing position so you don’t have to bend over to pull your cart around, then you return it to horizontal and it’ll slide back inside itself out of the way. I don’t have to necessarily use square tubing if you can come up with another way to do it using pipe or something else.
    Thanks for you input…here’s hoping you lose some sleep too !!
    Oklahoma City, Oklahoma
    304
    how about using the standard telescoping size for the handle, but at the hinge area, drop down another size or two. This might give you enough room to let the hinge be welded to the outside of the small tubing (or even say a piece of bar stock slid back into each piece of the handle), but still be smaller than the main handle tube allowing it to fit inside the cart rail. SSS
    Dec 2005
    Dallas, TX area
    267
    Default Just off the top of my head..
    Items in picture:
    1 - square tubing
    2 - blank endcap
    3 - 1/4 X 1/4 square stock
    4 - 1/4 X 1/2 square stock
    5 - slotted endcap
    6 - bar or pipe
    7 - 3/8 strap to fit inside the square tubing
    The square stock (3) is used as railing inside the tubing (1) by drilling holes in the sides and welding from the outside. The pipe or bar (6) slides in and out along the bar stock (3) like a drawer by riding on the strap (7) which also provides bearing surface for the torque of turning. When fully extended, the slotted endcap (5) prevents the bar/pipe from coming out. The smaller pieces of square stock (4) are welded vertically in the same fashion as (3) and when the bar/pipe is extended and raised in travelling position "capture" the strap against the slotted endcap. To move the bar/pipe back to storage position, rotate it slightly past level and push in.
    What do y'all think? I am sorry for the crudeness of my drawing.
    Triggerman
    Ammonia refrigeration tech
    Millermatic 180 w/Autoset
    CST-250
    HF-15 High frequency
    XR15 w/Push-Pull Gun
    Dec 2005
    Dallas, TX area
    267
    Default Improvement?
    If one of the slide rails were slightly shorter and a small piece of stock was attached to the bottom of the top strap, the handle would "lock" in the stored position and a simple twisting motion before extending would release it. Just a thought.
    I can see myself losing sleep over this until I build one.
    Triggerman
    CST-250
    17
    See Triggerman...you're as sick as I am !!
    17
    Already some cool ideas coming in at: http://www.hobartwelders.com/mboard/...ad.php?t=22813
    Thanks for all the help to the sleepless "engineers" around the world!!
    Dec 2005
    Dallas, TX area
    267
    Default Speechless.
    Quote Originally Posted by ronnielyons View Post
    It is what I do instead of having a life.
    Triggerman
    CST-250
    304
    I usually keep a pad and pen on the night stand just because some of my best ideas show up at 2AM! Why is that, anyway....SSS
