This wont be the only truck, but it will be the main welding truck. I currently have a working radius of around 75-80 miles from the shop, but I do go out farther to haul used pipe off of wellsites. Fuel mileage is not much of an issue to me (my daily driver only gets 7-8 mpg), but power is a must. Doesn't need to be fancy, I prefer vinyl seats with rubber floormats. Air conditioning isnt a must, but the radio has to work.
Bryce
BB Farm Supply
Results 11 to 15 of 15
Thread: New Welding rig
12-24-2006, 06:18 PM #11
- Nov 2006
- Shattuck OK
- 47
Miller Thunderbolt AC/DC
12-26-2006, 12:38 PM #12
- Nov 2006
- British Columbia
- 24
go cummins
The only disadvantage to the dodge cummins that I can see is it may not be the fastest truck off the line. Other then that it is the best work horse out there no matter the year . There our two kinds of people in the world,those that own a dodge and those that whish they did.
12-27-2006, 01:47 AM #13
The new Common Rail Cummins have plenty of problems to go with all that power and new ones are popping up all the time. The older trucks are virtually unstoppable. They have issues sure but they are all known now and can be dealt with. Injector pumps, Lift pumps, steering linkage and weak auto trans are what plague the older Dodge Cummins trucks. If you are going to stick that SA200 in it, try and find a low mileage 12V 1Ton. That or a 7.3 Ford 1Ton. Either brand with a manual and dual rear wheels is a fine work truck.
Hey why do a lot of people insist on spelling Cummins with a 'g'? Cummings?!?Cheers,
Chris
PipePro350 SS,Pro300,Pro300 SS,X-tremeVS,Dynasty200DX,Challenger172, SA-200 Redface,SA-200 Shorthood,SAE-300
12-27-2006, 09:22 AM #14
Guest
- Dec 2005
- Lodi, CA
- 1,495
From your previous post, it seems to me you'll be putting enough miles, it would be worthwhile to spend a few extra dollars on a good diesel, hurricunning had some good advice. Fuel savings alone will help give you a fast payback on the extra investment. Run the numbers both ways, gas vs. diesel.
12-27-2006, 10:08 AM #15
- Nov 2006
- Shattuck OK
- 47
