Results 1 to 10 of 12
Thread: convertion
    Nov 2006
    Laredo,Tx
    16
    Default convertion
    Hi everyone!
    I have a bobcat 225 welding machine,does anyone know if you can convert it
    into welding tig with it
    I already have e-mail miller co. twice and they haven't respond.
    I do not want to have to buy a tig welding machine. $$$$
    I also have a 251 mig,if i could convert it, which ever of them one or the
    other.
    P.S.Your comments will be appreciated
    Nov 2006
    Western, NY
    29
    You can use a tig on that machine. It will have a few limitations, maybe not quite as sweet as a high tech tig machine. I have ran them on many of my portables before.
    theweldor
    Nov 2006
    Laredo,Tx
    16
    Question for stainless
    what do i ask for,the leads or a conversion box at my welding supply store?
    I just want to tig weld stainless steel 1/8 thicke at the most.
    Nov 2006
    Western, NY
    29
    You will need a tig torch and cable with a gas valve built in the torch itself. There are several different styles. Some have a sliding valve some have a screw type valve similar to a torch valve. You will have what is called scratch tig as you will have to touch the material to start the arc. A little practice and it works rather well.You will need to run DCEN stainless and steel.
    Nov 2006
    Laredo,Tx
    16
    Default convertion
    Thanks alot for the info
    Dec 2006
    collinsville, ok
    86
    if you are going to run a dry rig for any length of time, i found it's good to use a torch that will handle the amperage with no problem. i use a 250 weld craft flex head for 3/8 & up. i run inconel so, i use a higher amperage anyway. (i've melted a few necks.)
    Dec 2005
    Dallas, TX area
    267
    Default The raw answer to your question
    Quote Originally Posted by P.the Heat View Post
    Hi everyone!
    other.
    In fact you don't need to do anything to your Bobcat to tig weld with it. You just need a tig rig to hook up to it. That would include the items listed above.
    I started tigging about a month or so ago with my gas-powered Miller. I bought a Tweco tig torch off of ebay, had a blown Victor flowmeter given to me and had it repaired, picked up a bottle of argon and protected my cables with a marvelous cover from http://stores.ebay.com/MJ-HOTcreations (thanks James and Mary). Total cost: $150. The stars really aligned for me on this one!
    Happy tigging!!!
    Triggerman
    Ammonia refrigeration tech
    Trailblazer 302 (yes, it's new)
    Millermatic 180 w/Autoset
    CST-250
    HF-15 High frequency
    XR15 w/Push-Pull Gun
    Victor O/A, DeWalt, North mask
    "A professional knows what to do. A craftsman knows why."
    Nov 2006
    Laredo,Tx
    16
    Default Raw answer
    Thanks Triggerman,For the info.
    I'am going to do it,this coming friday.
    Since i only got three days out of the week off,and i work out of town.
    Friday is the only day off out of the weekday.
    P.S. oops to much info
    Dec 2005
    Dallas, TX area
    267
    Default Great to hear it...
    Best of luck to you. Be sure to come back on and let us know how it goes. And pictures are always nice.
    Triggerman
    CST-250
    Nov 2006
    Laredo,Tx
    16
    Default finally
    Hey everybody.
    I already got the tig hoses and argon.
    I finally started practicing .It came with three sizes of tungstens and cups.
    I practice with each of them until i got the hang on them.
    The only thing i didn't like is that i have to scratch it to get it start .
    I was useing 10 gauge stainless steel.I was cutting strips and fuseing them
    together and it works awesome.
    P.S. At first i was using a strip of copper to scratch,but then i got a little
    tire.Then i started scratching on the stainless steel.
    Will it contaminate the tungsten
