    Orlando / Daytona, FL
    143
    Default Water cooled Vs Air cooled TIG torch?
    For say light duty 200 amp aluminum welding, how much of a difference is there between the two? Can you get away with a small tungsten with a water cooled torch?
    St. Johns Michigan
    216
    I hadn't used a air cooled torch in awhile, did a job with aircooled becuase I was to lazy to switch back to water cooled. I guess it's one of those things once you have used water cooled it's hard going back to a/c. Everything stays cooler including the tungsten.
    Pete
    Sep 2002
    Clark County, NV
    2,696
    Water-cooled is always the way to go if you can get or rig a cooler. I only have an air-cooled available in case I need to do some unexpected TIG while in the field off the TB.
    Nov 2003
    3,846
    along with staying cooler.. watercooled torches tend to be more flexible and physically smaller for the same amperage rating which makes a huge difference in getting into odd positions as well as a lot less fatigue at the end of the day.... after using a watercooled... switching back to gas cooled feels clunky and stiff..
    just my 2cents worth
    Heiti
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Mar 2005
    Vancouver,WA
    74
    I agree, I have never used an a/c torch but the Water cooled ones are the best! At school we run one on the sync 250 and it's great for what we do, I am probably the only one to actually weld 1/4" stainless at 250 amps and the torch never got hot although my pinky got warm since it was really close to the arc and the metal.
    Saving for Dynasty 200 DX
