Hi everyone!
I have a bobcat 225 welding machine,does anyone know if you can convert it
into welding tig with it![]()
I already have e-mail miller co. twice and they haven't respond.
I do not want to have to buy a tig welding machine. $$$$
I also have a 251 mig,if i could convert it, which ever of them one or the
other.
P.S.Your comments will be appreciated![]()
Results 1 to 10 of 12
Thread: convertion
12-09-2006, 02:55 PM #1
convertion
12-09-2006, 03:32 PM #2
- Nov 2006
- Western, NY
- 27
You can use a tig on that machine. It will have a few limitations, maybe not quite as sweet as a high tech tig machine. I have ran them on many of my portables before.
theweldor
12-09-2006, 05:17 PM #3
for stainless
what do i ask for,the leads or a conversion box at my welding supply store?
I just want to tig weld stainless steel 1/8 thicke at the most.
12-09-2006, 06:55 PM #4
- Nov 2006
- Western, NY
- 27
You will need a tig torch and cable with a gas valve built in the torch itself. There are several different styles. Some have a sliding valve some have a screw type valve similar to a torch valve. You will have what is called scratch tig as you will have to touch the material to start the arc. A little practice and it works rather well.You will need to run DCEN stainless and steel.
12-09-2006, 09:15 PM #5
convertion
Thanks alot for the info
12-10-2006, 02:55 AM #6
- Dec 2006
- collinsville, ok
- 86
if you are going to run a dry rig for any length of time, i found it's good to use a torch that will handle the amperage with no problem. i use a 250 weld craft flex head for 3/8 & up. i run inconel so, i use a higher amperage anyway. (i've melted a few necks.)
12-10-2006, 06:09 AM #7
The raw answer to your question
In fact you don't need to do anything to your Bobcat to tig weld with it. You just need a tig rig to hook up to it. That would include the items listed above.
I started tigging about a month or so ago with my gas-powered Miller. I bought a Tweco tig torch off of ebay, had a blown Victor flowmeter given to me and had it repaired, picked up a bottle of argon and protected my cables with a marvelous cover from http://stores.ebay.com/MJ-HOTcreations (thanks James and Mary). Total cost: $150. The stars really aligned for me on this one!
Happy tigging!!!Triggerman
Ammonia refrigeration tech
Millermatic 180 w/Autoset
CST-250
HF-15 High frequency
XR15 w/Push-Pull Gun
12-10-2006, 10:08 AM #8
Raw answer
Thanks Triggerman,For the info.
I'am going to do it,this coming friday.
Since i only got three days out of the week off,and i work out of town.
Friday is the only day off out of the weekday.
P.S. oops to much info
12-11-2006, 06:15 AM #9
Great to hear it...
Best of luck to you. Be sure to come back on and let us know how it goes. And pictures are always nice.
Triggerman
CST-250
12-16-2006, 01:00 PM #10
finally
Hey everybody.
I already got the tig hoses and argon.
I finally started practicing .It came with three sizes of tungstens and cups.
I practice with each of them until i got the hang on them.
The only thing i didn't like is that i have to scratch it to get it start .
I was useing 10 gauge stainless steel.I was cutting strips and fuseing them
together and it works awesome.
P.S. At first i was using a strip of copper to scratch,but then i got a little
tire.Then i started scratching on the stainless steel.
Will it contaminate the tungsten
