Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
  1. #21
    Mar 2006
    124
    With over 900K miles on one 69 F250 on one rebuild at 473K hard miles, yes had Dodge, Chebbie also. The FE (Ford) motor will save your A$$ in the long run (built correctly) like Miller welding products. Have had others thru the years as a test, a Miller for life member now.
    The above vehicles are pre 70's without plastic and cup holders.
    .....=o&o>.....
  2. #22
    synchro350guy Guest
    Default Nice job bumperman
    That is a great looking bumper but I do think u may have forgot about ur plate too...lol I built a wonderful bumper one time out of 2 -2" schedule 80 tubes slid through a pair of shaped plates to fit the truck with holes for the tubes. It looked awesome and was so simple.
  3. #23
    Oct 2006
    British Columbia
    500
    Cool Very good job
    But what about the licence plate
    and to the tigman 250 that drives a LADA car if you made the same bumper for the front then the D rings would come in handy for a FORD to pull you out of a very shallow ditch
    anyway on your bumper I think you did a good job better than most
    that I have worked with. Grade - B
