Thread: sevice bed
    Nov 2005
    Buhl, Idaho
    53
    Default sevice bed
    I built this bed over a year ago. I used 14G for the tool boxes, 1/8'' deckplate for the floor, and 3/16'' for the workbench. mounted just under the bench is receiver tube so I can put the vice on and off. I lost the pic that shows the rear of the bed, but I have a 5hp gas air compressor mounted in it. The welder is a Miller trailblazer 280. I could only work on it part time, so it took me about 2 years to finish.
    Quote Originally Posted by trevwelder
    Hey, nice looking work there! I have a question... how do you get to the oil drain and filter to do a service on the Trailblazer? I thought of mounting mine the way you did, but I wanted access for doing a service easily. Mine is mounted on the rear of the flatbed, centered and facing rearward.
    chaikwa.
    Nov 2005
    Buhl, Idaho
    53
    Quote Originally Posted by chaikwa
    chaikwa.
    Hi chaikwa, Thank you for the compliment. On the oil drain I use a hose that is 24'' long. I can reach the drain and the oil filter from reaching over the top. It is a tight squeeze, but not to bad.
    Appleton, WI
    193
    Thumbs up service truck - welder oil change
    Hi Chaikwa and trevwelder,
    If your welder/generator has a Kohler engine, Miller offers a remote oil drain and filter kit so you can change oil when the machine is mounted close to the cab of a truck. It remotes the filter and drain to the rear panel of the machine.
    You can check it out at www.Millerwelds.com/truck. That web site is dedicated to truck applications.
    Trevwelder, your truck does look nice.
