Results 1 to 4 of 4
    Nov 2006
    4
    Default Welder extension cord
    I have a new Miller 175 mig welder which has a male nema 6.50 plug. I want to plug it into my old Miller 225 amp stick welder outlet which is a female nema 10-50. I have a male 10-50 plug and am looking for a short cord ( 4-6') with one end a female nema 6.50 connector that is of appropriate wire size ......? 8 guage
    3 conductor. My breaker is a 70 amp breaker. Any idea where I might locate such a cord? Thanks for your help!
    Oct 2006
    642
    Quote Originally Posted by dongill View Post
    I bought some 8 ga SO 3 conductor wire, and the appropriate connectors and made my own extension cable. It's about 75 feet long. I use it on my Millermatic 210 welder.
    Nov 2006
    Appleton
    8
    You will not be able to purchase a cord with a 10-50 connector. The 10-50 connector is no longer supported by the National Electrical Code for welding. The connectors use today for welding equipment (6-50) have a dedicated safety ground. The ground pin in the 10-50 is a neutral connection, not a safety ground, and therefore does not meet the NEC requirement for welders. Check out the link below for a little more on this topic.
    http://en.wikipedia.org/wiki/NEMA_connector#NEMA_6
    I am Miller's Product Manager for the MM175. I suggest that you have an qualified electrician update your outlet.
    Dec 2006
    Wartburg,Tn
    575
    Talking Any pictures
    Do you have any pictures of it if you do E-Mail them to me at TOEJOEJONES88@yahoo.com[/EMAIL]
