    Mississippi
    4
    Exclamation Tig Settings on a Syncrowave 250???
    I have a Syncrowave 250 (older by the looks of it) in my shop, and was wondering if anyone could recommend what I need to set everything at to Tig alum. I'm going to a formal school in the near future for Tig, but just want to get it running right so i can practice a little before then! I played with it some, and can get it to arc, but it wont lay a bead down to save my life. I'm using all the settings the miller calculator says, but sofar all the filler does is ball up and roll around! . Any help would be greatly appreciated!
    Thanks ahead of time!
    DC in the CG
    Suffield, Ohio
    344
    How thick are you trying to weld
    Mississippi
    4
    Default Syncrowave 250
    all the test pieces are 1/8" thick. I've played with the amps, polarity and setting and sofar nothing will lay a bead down. I'm 95% sure its operator error tho!
    Mpls, MN
    1,762
    Maybe cause you need to be running AC for AL?
    Syncrowave 250DX
    Invison 354MP
    XR Control and 30A
    Airco MED20 feeder
    Thermal Dynamics Cutmaster 81
    Smith O/A rig
    East Tennessee
    137
    You may be better off to wait a little while & get the formal training instead of trying to learn it on your own. It's much easier to learn the right way to start with than to pick up wrong information & bad habits, & then have to unlearn them before you can get it correct.
    I wish I could have learned in a more controlled setting with an instructor there to help. Don't make his job harder by "learning" before he gets a chance to teach you the correct way.
    Mississippi
    4
    Default Syncrowave Tig
    Thats probably best. I'll just wait for my school to come up! Thanks, I appreciate everyone's input!
