Results 1 to 8 of 8
    Jun 2004
    Pittsburgh, PA
    111
    Default What thickness or gauge is standard automotive sheetmetal
    What thickness or gauge is standard automotive sheetmetal on American vehicles, such as a door skin or fender skin. I'm practicing up on my Mig and am trying to determine settings, using ER70-6S and C25. The tables in my texts and on the machine reference gauge. Thanks for any info.
    Default age ??
    it depends on the age mostly and some on the type.
    the newer cars will go 20 to 22 gage you might find it a bit thicker in a truck and my old 51 GMC 3/4ton is 16-18. seems like 14 gage
    Jul 2003
    TX
    77
    Be aware that this metal will not likely be ordinary mild steel.
    Jun 2004
    Pittsburgh, PA
    111
    The vehicle I'm planning to work on is a 1997 Jeep Grand Cherokee. I'm trying to do the work myself or myself with a few friends as a learning experience and to try to save some $. It's not my primary vehicle, so I'll take my time and see what happens. I am going to practice my welding on some scrap before I weld on the vehicle. I also bought a new Oxy/Acetylene kit today.
    Jun 2004
    Pittsburgh, PA
    111
    Quote Originally Posted by INTP
    What would it be most likely?
    Queens NY
    1,547
    Quote Originally Posted by dcsound
    carbon steel, or a similar alloy. In the case of many gm vehicles it is also zinc washed
    Jun 2004
    Pittsburgh, PA
    111
    Then maybe I should be using a different mig wire and gas combination?
    Texas
    279
    DC, for patch panels at the college autobody we use 18 ga. mostly but at times will use discarded hoods/fenders for patches, for your Jeep I'd use 18 ga. and we use .023 and C25 for all. Remember to clean w/wax and grease remover before ya start or grinding at the patch area has a possibility of contaminating w/silicons, and your paint will not like it.
    Good luck
    L*S
