Results 1 to 10 of 16
    Richmond Virginia
    5
    Question Initial settings for 30A Spoolgun
    Just got a Miller 30A spoolgun attached to my Millermatic 250. I will be practicing on 1/8 Al coupons using .035 wire, Argon at 20cfm. As the control module I bought doesn't have any knobs it looks like the 250 will control wire speed and voltage. Does anyone have any suggestions for initial settings or general tips for learning to use the spoolgun for Al??
    Dr Gas
    Millermate 250, Dynasty 200DX, 30A Spoolgun,oxy-acetylene, Pak-Master 38XL Plasma, Forgemaster forge, HF 110 anvil, Peddinghaus 275 anvil,
    Lake of the Ozarks MO
    3,594
    Isn't there a red knob on the bottom of the handle? That adjusts wire feed.
    Also I prefer bigger .064 wire myself. It has a lot less wire feed associated problems.
    Cleveland, Ohio
    38
    Short circuit transfer for Aluminum (ER4043)
    Wire Voltage WFS ipm Amps Shielding gas
    .030 16-19 250-550 50-120 Argon
    .035 17-20 240-425 65-140 Argon
    .045 17-22 160-325 75-170 Argon
    Spray Transfer for Aluminum (ER4043)
    .030 20-27 550-1200 95-200 Argon
    .035 20-27 425-850 110-220 Argon
    .045 22-31 250-650 130-290 Argon
    From GMAW book in Miller student package.
    Jan 2006
    122
    I would get some 1/4" material to start out with. If you are just starting out with a spoolgun on aluminum, 1/8" stock may be a little difficult until you get a feel for it. I just recently went through this same process.
    East Tennessee
    143
    Wire size shouldn't be a problem with a spoolgun
    Default spoolgun 30A PROBLEMS INTALLATION
    Hio I just bought a spoolgun 30 with remote control ,I have a old millermatic 250 ,so I have problem installing the remote control becuase I cant find the pg7 plug from the welder I need help if anyone can help me please reply Thanks Ernest
    May 2006
    180
    Dr. Gas, regarding a connection for your spoolgun....did you install or was there already installed on your welder the optional receptacles module for connection of a spool gun? For info check the owner's manual for your welder or if you don't have one, download one from this site by inputting your model and serial number at http://www.millerwelds.com/service/ownersmanuals.php
    No hijack intended here. Can anyone translate the WFS ipm settings copied above by tenfingers into the 0-10 control settings on the handle of the 30A? The best I've heard on this so far is to adjust the 30A on-the-fly. Is there an equivalency chart somewhere for those of us connecting the 30A to a power source with no ipm readout?
    Miller XMT-350 CC/CV
    Miller S-22A wirefeeder
    Bernard 400A "Q" gun
    CK 210 & WP-18 GTAW torches
    Hypertherm Powermax 30
    Jan 2008
    very eastern MA
    114
    measure how much wire comes out in 6 seconds and multiply it by 10= IPM
    or 12 secs and X 5
    G
    Arizona
    119
    The owner's manual states 70 To 875 ipm wire feed speed. At a zero setting you should be getting 70 ipm and at a 10 setting, 875 ipm. I would expect it to be a linear progression in between. If that's true, at a 5 setting, you should be getting 502.5 ipm. You can verify that by using the technique gordfraser posted.
    GS
    Aug 2004
    Milan Michigan
    1,866
    I dont see the need to know that, Set the voltage or temputure and then fine tune wire speed as your welding.
    Doing it this way will by far give you better results that a pre determined setting by the factory.
    In put voltage from the utility and what machine your using will vary.
    Using settings that the factory recommends will however get you close.
