Results 1 to 10 of 10
    Sep 2006
    Wheeling
    169
    Default Looking for very fine TIG fill rod
    I am looking for some very fine or even ultra fine TIG fill rod. I need something like 70S that is smaller than .125, anyone have any ideas. THis is to work on a very small sculpture and is maybe 2 inches square with 20 or soe internal pieces that to be welded in place.
    Just an artist idea that I am trying to make it work..
    Jerry
    Mpls, MN
    1,762
    Hummm... Smaller than 1/8" Gee, maybe some 3/32"? Some 1/16"?
    I'm thinking you might want something more like .045" or the smaller wire gauges. Any of which can be bought in cut lengths.
    Syncrowave 250DX
    Invison 354MP
    XR Control and 30A
    Airco MED20 feeder
    Thermal Dynamics Cutmaster 81
    Smith O/A rig
    Suffield, Ohio
    344
    Use mig wire.
    East Tennessee
    136
    Quote Originally Posted by jfsmith View Post
    Jerry
    Just use some MIG wire!
    Jan 2006
    Albuquerque, NM
    1,788
    Hmmm, Untra Fine, maybe he is looking for .0125 and dropped a zero. If not then .030 is avail in cut lengths from most suppliers, or as been suggested use mig wire in .023 or larger sizes.
    Regards, George
    Sep 2006
    Wheeling
    169
    I will probably cut some MIG wire to fit, that is a good idea.
    Many thanks,
    Jerry
    Mpls, MN
    1,762
    The professor should know attention to detail is important.
    Tigging with mig wire that isn't straight is annoying to me, so the added 30 cents per lb is worth it to me for cut lengths of straight wire.
    Syncrowave 250DX
    Invison 354MP
    XR Control and 30A
    Airco MED20 feeder
    Smith O/A rig
    Sep 2006
    Wheeling
    169
    I generally just pull the MIG wire thru something like a hole in a board to straighten it out, sometimes more than once. It has worked in the past.
    Jerry
    Jan 2006
    Albuquerque, NM
    1,788
    I have an old dental tool that looks like a pair of pliers with three small holes in the jaws (I think it's used to deal with wire for braces maybe), clamp the wire in one of the holes and pull it thru and it comes out stright. Flea market for $1, don't use it much as like Jim I prefer to buy cut lengths but it comes in handy once in a while.
    Regards, George
    canada
    65
    Cut a few feet off the spool clamp end in vice.10 ft lengths are easy to manage
    Put other end in your drill pull it tight and start the drill .Speed of drill fast is ok.
    Just like magic the wire begins to straighten out. Make yourself custom lengths to weld with in any diameter of mig wire.
    Ronnie
