Results 1 to 4 of 4
    Nov 2006
    2
    Default miller maxstar??
    Hi, in a few weeks i will be welding bicycle frames together. The tubing i will be using will mainly be .049 wall thickness 4130 chromoly. Though i will have to weld to 3/16 inch thick dropouts also. Those are pretty small though. I was wondering if the maxstar stl or sth would be sufficient to weld this metal.
    Nov 2006
    Crossville, TN
    87
    You should be able to weld these with your Maxstar just fine. I have one and weld motorcycle frames, swingarms and exhaust sysytems all the time.
    Nov 2006
    2
    You do mean a maxstar 150 right, just want to make sure because i forgot to specify in my post.
    Nov 2006
    Crossville, TN
    87
    Yes, I have the Maxstar 150STL with finger tip control. It replaced the Econotig that was supposedly stolen while I was at sea, in 2000.
    You might grow out of the Maxstar before too long. I did, and will be picking up a Syncrowave 250DX when I return home and start stocking my new shop.
