Results 1 to 2 of 2
Thread: 1020 DOM tubing
    getfuzzy Guest
    Default 1020 DOM tubing
    First post Hi out there in welding land, any tips for welding 1020 DOM.Thanks
    855
    What kind of advice are looking for ? My experiance welding it has always been very good,the stuff welds great.If you have novice skills or better you will have no problem. Its a good low carbon steel to weld, just get the stuff clean and make your fit nice and tight, dont leave gaps and weld air, take the time to make the fit and it will be a much better weld over all. I have welded a lot of it over the years and never found it to require any new tricks. What are you building ?
