Results 11 to 15 of 15
    Nov 2009
    Default hey tbucket
    I am just curious if you got your bluestar running or if you were going to sell it as it said in the other post you have on here. thank you
    Apr 2008
    BC, Canada
    10
    I've put it away until next spring. Never had a chance to get it working since the carb was full of dust. I will sell it if the welder part is hooped.
    Apr 2008
    BC, Canada
    10
    Default I got it running finally
    I got it running finally... runs really good. Used the 110 outlets to power a shop vac. Its set up to run on full throttle so its putting out 320 volts according to my DMM. I used some baling wire to hold the throttle on the carb mostly closed so it only pits out 120 volts. I'm looking at it trying to figure out how I can change the rpm since there appears to be no throttle lever on it. Too bad there is not a volt meter on it or tach... since the fine print on it says 1800 rpm for 110\120 and 3000 rpm for 220\240...
    Nov 2010
    Wisconsin
    Default Anyone know where to get faceplates for the 2e?
    I have a Bluestar 2E on my mobile service truck, I am extremely fond of that machine. However the faceplate is more than a little faded I remember seeing a website a year ago (no money) that sold them. I cannot find that site now that I have money again, any help would be appreciated.
    3,953
