Results 11 to 20 of 24
    Mpls, MN
    1,790
    You might just want to make a bushing to take up the space between the drag tip and the cup. If I remember right, that piece is one of the spendier replacement items. It'd be a shame to lose it.
    Syncrowave 250DX
    Invison 354MP
    XR Control and 30A
    Airco MED20 feeder
    Thermal Dynamics Cutmaster 81
    Smith O/A rig
    Quote Originally Posted by Fishy Jim View Post
    Great idea, I'll try that. You are right - drag cup, drag tips, and drag shield ran me about $80 all together. I'm a little disappointed that Miller sells parts that don't accomplish the single purpose for which they are intended.
    Mpls, MN
    1,790
    Thermal included all of that, and the stand off bracket for the non-drag tip.
    The little parts kit included was actually rather well stocked.
    Syncrowave 250DX
    Invison 354MP
    XR Control and 30A
    Airco MED20 feeder
    Smith O/A rig
    Plainview, TX
    334
    Hypertherm makes all the hand held plasma torch handles for Miller. Looking at Hypertherms equipment, I suspect they make the Spectrum 125C and 375 for Miller as welll. Hypertherm does have some accessories that Miller doesn't have listed. The Hypertherm accessories that are identicle or nearly identicle are running about the same price or a little less than the equivalent Miller parts. The Hypertherm circle cutting guide cuts a bigger diameter circle than Miller and is significantly lower in price by the time you got all of the Miller parts to do the same thing. Miller seems to have some great partnerships for torch and gun handles for their gear.
    Whatever you do, don't buy any Thermal Dynamic parts, guns, or gear for your Miller, others here on the forum have had problems mixing components. As long as you stay with Hypertherm/Miller you should be good on your parts and accessories.
    As far as patterns go, making them from plywood or hardboard would be the way to go. I even saw one of the guys on CMT Trick My Truck use the flange from the light kit he was installing to cut the hole in the truck bumper. Fit perfectly.
    Have fun with your new gear.
    '77 Miller Bluestar 2E on current service truck
    '99 Miller Bobcat 225NT for New Service Truck
    '85 Millermatic 200 in Shop
    '72 Marquete 295 AC cracker box in Shop
    '07 Hypertherm Powermax 1000 G3 Plasma Cutter in Shop
    Miller Elite and Digital Elite Hoods
    Mpls, MN
    1,790
    3390: Here's the drag tip for the 1Torch. You can see some of the air flow vents for cooling. The tip then tucks up inside this where it's protected from most of the blow back.
    I used this inside an enclosed circle jig and that's why it's all crappy looking. The soot just wipes off.
    3391: This is how the consumable tip comes off for replacement.
    Syncrowave 250DX
    Invison 354MP
    XR Control and 30A
    Airco MED20 feeder
    Smith O/A rig
    642
    Quote Originally Posted by vtwin4life View Post
    My 375 is bone-stock, just got it a couple days ago. The drag tip, cup, and shield are Miller parts. There is no gap between the tip and the drag shield. I called Miller tech support yesterday with this exact same question. The technician was very helpful. He went and got all the parts to see for himself. The good news - he came up with exactly what I had - no standoff with all the drag parts. The bad news - no standoff with all the drag parts. He literally told me he didn't know what to say. Anyway, I have decided that I am going to unscrew the drag shield enough to give me 1/16" stand off and see if it works. I did it last night with the power turned off, and just dragged the tip to see if the loose drag shield would unscrew anymore, it didn't seem to, so I think this weekend I will try a live test.
    Can't wait for Saturday for my electrician to install my 240v drop in my garage so I can really give this machine a good run. Quite frankly, this machine is probably way more than I needed, and beyond my skill level, but I'm hoping to catch up. And besides..... It's just sooooooo cool ;-)
    OK so what you are saying is " bone-stock " the 375 comes with a Drag Tip?
    On page 28 of the 375 Manual it shows a break-down of the torch tip end. It shows two sets of images one shows a Retaining Cup ( 202 808 ) and Tip ( 176656 ), it then shows a Drag Shield ( 225616 ) Retain Cup Drag Shield ( 225672 ) and Tip Drag Shield (225671 ). Numbers in brackets are Miller Part #.
    I just got my 375 about 2 weeks ago and it did not include the drag tip.
    When I look at the manual I can see that the Drag Shield mounts on to the front of the Drag Shield Retaining Cup - the Retaining cup is the large round cover that you remove to replace the tip and electrode. If the cup on your Torch is a 2 piece unit, cup/shield then I would say it is the Drag setup. If it is just a round fiber tubed with a brass threaded insert and tapered to a flat spot where the tip protrudes it is not a drag cup.
    What is does not say is which configuration is STANDARD.
    In the ICE 27C/T Consumables Kit sold by Miller that 202-808 Non-Drag Retaining Cup is included as well as the 176656 Tips and 175655 Electrodes.
    Now according to miller web site the 375 cutting capacity is as follows.
    Rated 5/16 Quality 3/8 Sever 1/2
    Using a 1/16" Standoff it goes like this ...
    Rated 3/8 Quality 1/2 Sever 5/8
    I have included two photos .... cup1.jog shows the cup that comes with the 375 and also in the consumables kit. If yours looks like this, according to the manual it is not the Drag version.
    cup2.jpg shows the part number on the tip of the cup as well as close of of the lip. If I had a Drag Ret Cup I would show that but I do not.
    Hmmm a search brought up this link to a dard PDF file but it mentions the drag parts ( this is for the Extreme version but the Torch is the same and is shown on page 3 of the PDF )
    http://www.millerwelds.com/pdf/spec_sheets/PC9-2.pdf
    642
    By the way,
    I love the 375 ...... we've gone through a tip or two just cutting up stuff for the fun of it.
    When we wanted to remove to good lawn mower engines from trashed deck ...we just cut em out!
    hahaha
    Mpls, MN
    1,790
    How many feet of cuts have you been getting per tip and what thickness of material?
    I'm approaching 100ft on my first electrode, and it's still not worn. Tip is the same thing. I have a 40A that I've been beating on and it's only slightly showing wear. Mostly 1/8" and 3/16" sheet, but I've also cut some 3/4" and expanded as well.
    Syncrowave 250DX
    Invison 354MP
    XR Control and 30A
    Airco MED20 feeder
    Smith O/A rig
    642
    Honestly I have not kept a record. I've been cutting up a ton of stuff for the heck of it. ( to wear out the NOVELTY of having a new toy ) Now that we are through that phase I will keep track of plasma usage. Wont be hard to make a lil chart and keep it along side the cutter and 'try' to guage usage.
    Thickness? Well lets say the first tip was used cutting the thickest and nastiest metal we could find ... even doubling up in some cases, just to see what would happen.
    Mpls, MN
    1,790
    I bought mine for a specific project, so I can look at my parts inventory and see exactly how much the consumables have gone through. Not that I'm keeping meticulous records, but more that I can simply see what's been done thus far.
    I've been very pleased in the TD's performance. It's a time saver for sure.
    Syncrowave 250DX
    Invison 354MP
    XR Control and 30A
    Airco MED20 feeder
    Smith O/A rig
